Home > Puma (Tdci) > Rattling Brakes !! |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
As the title sugests really !
Took my DEFENDER back to the dealers for a very annoying rattle ! Turns out it was something to do with the brake pads ? i couldnt find out what the exact problem was but i suspect wrong pads or no anti rattle shims ! To be honest i thought the brakes were a bit pants ! hopefully the rattle should now stop and the brakes will be better ! any one else suffered from this ? DEFENDER XS CSW 08 TONGA GREEN |
3rd Jun 2008 5:53pm |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 825 |
I think this is a common problem as mine were done only last week having covered 3000 miles. Seems like the shoes are too small for the callipers or something like that
5th Jun 2008 7:45am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Mine does it too - as did the TD5 before it. I'll be mentioning it to the dealer when it goes in for a new pinion seal next week.
5th Jun 2008 3:31pm |
GOOD !
As long as i,m not the only one ! I mean i wouldnt want to be the only kid in the sweet shop would i So the likelyhood is that they will do this again then ? DEFENDER XS CSW 08 TONGA GREEN |
6th Jun 2008 5:03am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
mine has done it also, but apparently now there is a bulletin and fix from the dealer, its in next week to be fixed
26th Aug 2008 4:59pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Your not alone in the sweet shop Mine rattles a good un i just keep the windows up and the music loud |
26th Aug 2008 6:26pm |
Well having the dealer do the mod to fix the rattle guess what - its back having covered a further 1800 miles
Back to the dealers or should I say stealers |
27th Aug 2008 5:29pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
1800 miles! is that a typo - as if it isnt they would be in serious trouble from me Mike |
27th Aug 2008 5:52pm |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
my brake pedal rattle occasionally and only occurs during the car is not running. Ive talk to my dealer regarding this but I cannot duplicate the problem as it only appears very seldom. I know its not regular but its annoying... it just appear for a couple of seconds... its sounded like grrr grrr with rattle on the pedal. My car by the way is 2008 D110.
anyone who has the same pridicament? Last edited by totoD110 on 25th Oct 2009 12:51pm. Edited 1 time in total |
24th Oct 2009 6:54am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
abs modulator. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
24th Oct 2009 10:42am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
Mine had it and dealer replaced them by the new type. Puma 110" SW
24th Oct 2009 12:15pm |
Thank you sir I''l let them know this... thanks a lot! |
25th Oct 2009 6:54am |
so Im not the only one. thanks for the tip sir! |
25th Oct 2009 6:56am |
GR110P Member Since: 16 Aug 2009 Location: GR Posts: 15 |
I have a similar problem.When I drive I can hear a sound like "kak...kak...kak....kak..." from the front left wheel.And when the wheel hits a bump or hole on the road,I can hear a rattling sound.
I found out that its coming from the brake pads.The two pins that hold them in place ,on the left wheel are too loose on the brake caliper.I can also hear a 'kak' sound when I hit the brakes for a sec. |
28th Oct 2009 11:03am |
