Home > Td5 > Strange noise on overrun. |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Propshaft journals.
Check with wheels chocked, out of gear and handbrake off. Rear of front shaft most likely. |
24th Apr 2013 4:41pm |
3216andy Member Since: 22 Oct 2011 Location: south lincolnshire Posts: 18 |
Probably blindingly obvious to those in the know, but what am I checking for exactly? It just gets louder, not faster.
24th Apr 2013 4:49pm |
Any freeplay in the journals or the flange fastenings.
24th Apr 2013 4:55pm |
Spot on Laurie
Easy job to tackle? It just gets louder, not faster. |
24th Apr 2013 5:09pm |
Just go underneath and try to move each end of each shaft.
A push-pull motion should be repeated at approximately 90 degrees to the first attempt. If everything seems secure there are several other possibilities. |
24th Apr 2013 5:33pm |
Sorry, that last post was not clear, I been and checked, there is play, rear of front shaft as you predicted.
Is it easy to repalce? It just gets louder, not faster. |
24th Apr 2013 6:27pm |
You need to remove the propshaft complete.
A replacement universal joint is around £30 (OEM ones come in a Britpart box!), best to replace both while it's out. If you're unsure how to do it a local garage will charge you for about an hour. Once you've got the shaft out engage the difflock and take it for a drive. If you still get the noise then that's not your problem. Don't forget to take the difflock out after you've put the repaired shaft back in. Alternatively, a new propshaft will cost about £160. |
24th Apr 2013 7:13pm |
Thank you Laurie, most helpful. It just gets louder, not faster.
25th Apr 2013 4:12pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8032 |
i would GKN hardy spicer ones if you are doing UJ prop joints. bar far the best quaility for the money. Bearmach do them. Its a pretty easy job - once you have seen how to do it. have a look in the tech archive on lR4x4 there is bound to be a write up on there about it. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Apr 2013 4:15pm |
Britpart ones are GKN as far as I know.
I've just had my front prop done. |
25th Apr 2013 6:01pm |
all is good then.
£30 seems steep though. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Apr 2013 7:49pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
For info, I bought a pair of genuine GKN HD ujs (oversize bearings) for my Puma DC rear prop a couple of weeks ago from Dingocroft for about £19 each.
25th Apr 2013 8:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Heavy duty uj from bailey Morris is £25
Andy |
25th Apr 2013 8:27pm |
I was judging the price by Ebay prices.
Haven't had the bill from my garage yet. |
25th Apr 2013 8:40pm |
