Home > In Car Electronics > Extra cigar and USB sockets
bear100
I am looking at fitting extra cigar sockets and USB charger sockets in the rear of my puma 110,
Are there any makes I should go for?
Any pointers on wiring and where to take a Feed from?
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #225324 7th Apr 2013 9:55pm
Brendan on here is your man for those. Thumbs Up Regarding wiring if your not going to exceed 10A draw (dash socket max load) across all lighter plugs at one time then you could just tap into the existing one and to the new one then you will have two that are both usable. But just make sure you don't exceed the max draw. If you have items that you want to use at the same time i.e. a 6A draw item and another 6A used totalling 12A then that would be too much in which case the new 12v lighter plug would have to be wired independently fused again at 10A. Most charging items such as Sat Navs or phone chargers use under 2A draw so it maybe worth looking at the first solution. There's also the Illumination that can be tapped into too.
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #225327 7th Apr 2013 10:52pm
TJ101
Re: Extra cigar and USB sockets
In the rear, on the right hand side, behind the speaker ? panel.
there is a 12v live power supply,, purple/white ? from memory California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #225335 7th Apr 2013 11:18pm
purple and black Tim Thumbs Up - and it's fused, I just can't remember on which circuit Embarassed
I don't understand why people are swapping their 12v sockets to usb or twin usb when you can but usb plugs that fit flush and have either 1a or 1.5a output
Post #225346 8th Apr 2013 7:29am
TJ101
IIRC its on it own fuse/circuit, under the right hand seat, sometimes the feed is disconnected, and need reconnection again under the brake master cyl,,
Ditto,, have 2/3 griffin twin usb plugs, work fine California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #225350 8th Apr 2013 7:45am
bear100
I don't think I will use more than 10A at a time, engel fridge 1.5A, an iPhone, an iPad and mabe charging a maglight.
It make more sense to fit a USB bullet in a socket, you have both options!
What's Brendon's screen name Steve Thumbs Up
Under the rear passenger seat is it tj
Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #225580 8th Apr 2013 9:31pm
http://www.defender2.net/forum/member-leeds.html
Post #225584 8th Apr 2013 9:36pm
TJ101
No,,, Front RH Seat (Driver in RHD Cars) California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #225592 8th Apr 2013 9:55pm
bear100
Cheers guys
Thumbs Up Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #225603 8th Apr 2013 10:13pm
bear100
What size and type of cable should I use for this job? Don't want to look a fool in the merchant Embarassed
Post #230038 23rd Apr 2013 10:13pm
I'd use thinwall automotive. Or do you mean actual diameter and current rating?
EDIT* Sorry should have read your post more through more thorough. Embarassed
1mm would do with a 16.5A rating easily enough for what you want. Not over kill nor so small it's fiddle to work with.
I would also fuse what ever your putting in too unless it is already.
Post #230039 23rd Apr 2013 10:20pm
bear100
Cheers steve
This wall automotive Thumbs Up 0.5mm?
Post #230040 23rd Apr 2013 10:22pm
^^^^ Please see edit above. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #230042 23rd Apr 2013 10:24pm
Some here: http://stores.ebay.co.uk/Choice-Cables/Thi...34.c0.m322
or if you don't use E-bay then Vehicle Wiring Products.eu are good also. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #230045 23rd Apr 2013 10:28pm
bear100
Cheers Steve that's awesome just placed an order
Post #230048 23rd Apr 2013 10:42pm
