Home > In Car Electronics > Extra cigar and USB sockets |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
Brendan on here is your man for those. Regarding wiring if your not going to exceed 10A draw (dash socket max load) across all lighter plugs at one time then you could just tap into the existing one and to the new one then you will have two that are both usable. But just make sure you don't exceed the max draw. If you have items that you want to use at the same time i.e. a 6A draw item and another 6A used totalling 12A then that would be too much in which case the new 12v lighter plug would have to be wired independently fused again at 10A. Most charging items such as Sat Navs or phone chargers use under 2A draw so it maybe worth looking at the first solution. There's also the Illumination that can be tapped into too.
No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Apr 2013 9:52pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
In the rear, on the right hand side, behind the speaker ? panel. there is a 12v live power supply,, purple/white ? from memory California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
7th Apr 2013 10:18pm |
purple and black Tim - and it's fused, I just can't remember on which circuit
I don't understand why people are swapping their 12v sockets to usb or twin usb when you can but usb plugs that fit flush and have either 1a or 1.5a output |
8th Apr 2013 6:29am |
IIRC its on it own fuse/circuit, under the right hand seat, sometimes the feed is disconnected, and need reconnection again under the brake master cyl,, Ditto,, have 2/3 griffin twin usb plugs, work fine California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
8th Apr 2013 6:45am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1921 |
I don't think I will use more than 10A at a time, engel fridge 1.5A, an iPhone, an iPad and mabe charging a maglight.
It make more sense to fit a USB bullet in a socket, you have both options! What's Brendon's screen name Steve Under the rear passenger seat is it tj 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
8th Apr 2013 8:31pm |
http://www.defender2.net/forum/member-leeds.html
8th Apr 2013 8:36pm |
No,,, Front RH Seat (Driver in RHD Cars) California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
8th Apr 2013 8:55pm |
Cheers guys
8th Apr 2013 9:13pm |
What size and type of cable should I use for this job? Don't want to look a fool in the merchant
23rd Apr 2013 9:13pm |
I'd use thinwall automotive. Or do you mean actual diameter and current rating?
EDIT* Sorry should have read your post more through more thorough. 1mm would do with a 16.5A rating easily enough for what you want. Not over kill nor so small it's fiddle to work with. I would also fuse what ever your putting in too unless it is already. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 23rd Apr 2013 9:23pm. Edited 1 time in total |
23rd Apr 2013 9:20pm |
Cheers steve
This wall automotive 0.5mm? 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
23rd Apr 2013 9:22pm |
^^^^ Please see edit above. No Guts, No Glory.
23rd Apr 2013 9:24pm |
Some here: http://stores.ebay.co.uk/Choice-Cables/Thi...34.c0.m322
or if you don't use E-bay then Vehicle Wiring Products.eu are good also. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
23rd Apr 2013 9:28pm |
Cheers Steve that's awesome just placed an order
23rd Apr 2013 9:42pm |
