Home > Technical > You carb fed V8 tech kings |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Had exactly the same problem with a 1990 V8 carb fed Discovery, it was venting after any length of journey.
It actually went back to LR to investigate and fix. All I can remember is that it can back with longer vent pipes Not a lot of help really. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
23rd Apr 2013 6:43pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
If its got SUs it is most likely that the float needles or seats need replacing as they have worn, Ive done this on HS and HIF carbs and its not hard but never on a Rover V8 but expect its a simular arrangement. Would expect a good manual to cover how. Another thing to check is the fuel pump if an aftermarket high pressure one is fitted it can overcome the floats and you will need a regulator
good luck DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
23rd Apr 2013 7:07pm |
