Home > Technical > You carb fed V8 tech kings
familymad
Stock 1985 3.5 V8 CSW. Only done 8 k in last 7 years but serviced every year. New short block when re built in 2006 and carb exchange re did the twins.
I buy it and have done 2k in last month, almost a shakedown since its re build. Question is .......
2 little pipes which vent into passenger side wing area. Obvious that they come from the 2 carbs. Would expect a little bleed on short runs/choke but it's doing good long 35 mile journeys each day and you can see it venting even after that?
Floats? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #229755 22nd Apr 2013 9:07pm
bob neville
Had exactly the same problem with a 1990 V8 carb fed Discovery, it was venting after any length of journey.
It actually went back to LR to investigate and fix. All I can remember is that it can back with longer vent pipes Shocked
Not a lot of help really.
Bob Shocked 2015 Jaguar XE240 R Sport - goes like ....... !!
2013 Defender 90 CSW - sold
Post #229970 23rd Apr 2013 6:43pm
LR90XS2011
If its got SUs it is most likely that the float needles or seats need replacing as they have worn, Ive done this on HS and HIF carbs and its not hard but never on a Rover V8 but expect its a simular arrangement. Would expect a good manual to cover how. Another thing to check is the fuel pump if an aftermarket high pressure one is fitted it can overcome the floats and you will need a regulator
good luck DEFENDER 90 TDCI XS,
Post #229977 23rd Apr 2013 7:07pm
