Home > Maintenance & Modifications > Need advice about garage fallout / gearbox failure! |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
I think you need to find out the reason why the failures have happened. Have they forgotten to fill the gearbox up with oil causing the failure? Did they forget to do something up tight enough causing the power steering leak? If so then it is clearly their fault. However if a seal has just gone pop on the power steering and your gearbox has just gone bang for a normal reason then it probably isn't their fault. More investigation required i think.
HTH Mark |
22nd Apr 2013 11:50am |
Did the garage rebuild the gearbox too or just bolt it in the new chassis? If they just swapped it over did they refill with oil? You need to check what catastrophic failure the gearbox suffered before accusing really.
Beaten too it by mark
22nd Apr 2013 11:51am |
Only by a fraction of a second though i think. Can't workout why i am always double posting though...
22nd Apr 2013 12:49pm |
Pierce.M Member Since: 17 Jul 2012 Location: Newcastle Posts: 16 |
Thanks for the advice chaps ... will post an update when I find out the exact problem.
22nd Apr 2013 12:51pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
get it independently checked by a proper engineer and havevhim write a report on his findings
22nd Apr 2013 8:21pm |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
Is there any reason why it took a specialist LR garage 2 months to do a chassis swap? Marsie on here does them within a fortnight on his own!
22nd Apr 2013 11:17pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Need the full facts first,, what,s failed
Why would the garage drain the box oil, ? just to remove from one chassis and fit to another So long as you don't go "shouting the odds" yet !, sure the garage will have a look, and see what the problem is,, and if down to them,, will put it right for you
depending how much over £3k,, ?? I would say, if that inc all parts and labour, a very fair price California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
23rd Apr 2013 7:46am |
