![]() | Home > Td5 > Front and rear diff oil - quanties |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
1.60 Ltrs
And on later Defenders its 75W/90 Synthetic gear oil, not EP 90 ![]() Edit ... Thats 1.60 ltrs per diff [not in total] Guns and Landrovers .... anything else is irrelevant. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
Cheers. That's the one, 75w/90
Time to get some on the way home ![]() Regards John M0VAZ Econet Station 48 no clock |
Picked up 5l of 75/90 and then found in the shed another 2.5l of the stuff!!!
Same oil as the transfer case it seems according to the Haynes manual. Well it shows MIL-L-2105 specs for both oils (75/90 for transfer case and 80EP or 90EP for axles) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yea Transfer case is the same
![]() And ... depending on who you listen to/read etc ..... so is the gearbox ![]() |
I emailed an oil company a while ago and the alternative MTF94 was a syntrax 75 oil. Handy having the same oil as the transfer case. I guess the Evo oil from another forum is 75 based oil.? 1999 Defender TD5 110
I'm waivering a bit with regard to main gearbox [on the Puma], although others are happy its the same stuff
![]() Castrol's own spec sheet states BOT 130M is a fully synthetic Transmission fluid, which is not the same thing as a fully synthetic Gear oil [even if the viscosity is the same at 75W/90]..... Might just be me being too pedantic ............. ![]() |
