Home > Puma (Tdci) > Any idea what this is? |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 |
looks like you ripped off your shoelace upon exit!
no idea otherwise. 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
24th Jan 2010 3:31pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
That is what I thought at first as well. It appears to be made out of a foam rubber like material.
24th Jan 2010 5:30pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8114 |
isint it just part of the sealing foam between the lower sill panel and door section? i wouldnt worry about it Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Jan 2010 5:55pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
just a bit of weather seal between the sill panel and the body. I'd say fix it yoursef (don't get the dealers to do it) - I wish I had !
24th Jan 2010 7:05pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
Mine came off some time ago, it's nothing to worry about. Just pull the loose bits off. 130 crew cab
98 V8 Disco |
24th Jan 2010 8:01pm |
Thanks for the info all.
Is there a product that one can get, either online or from Halfords, that would do the trick? I tried pushing it back in and it doesn't stay. |
24th Jan 2010 8:12pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
That's basically the draught-excluder foam that they fit to fill the panel gaps. Definitely get the dealer to replace it, although it is pretty rubbish foam and seems to perish pretty easily. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
24th Jan 2010 10:04pm |
