Home > Puma (Tdci) > Those with winches |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 |
no, have an equipe winchbumper with winch and still on standard suspension
1st Jun 2008 9:04am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Great - makes my life easier
Just to order another winch bumper not to get the brand new warn winch out of the box at 6 months old! Mike |
1st Jun 2008 9:40am |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 |
i thought i'd keep my standard set up but after a few months decided to up-grade, IMO it's worth doing it , truck looks better and sits better on the road. it's only £180 for a pair of OME's....
1st Jun 2008 1:32pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
On the 07, have the Factory winch and front bumper fitted,, and at present the standard front springs,,which even with 255/85 MT. have been OK,,, but truthfully, they are in need of changing to something a tad stiffer !! another job on the list sometime California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
1st Jun 2008 5:26pm |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 |
I upgraded to OME and it is alot better than before, I found that with the winch and standard springs it got a little bit wayward at the rear end! 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
1st Jun 2008 8:43pm |
So its a bit of a split at the minute, between the old rule i had of they need to change and they will be fine.
What im trying to work out is the usual heavy duty front springs are 90 rears - although the CSW is supposed to have the Heavy Duty all round from the factory - so what springs have you guys been using on the front? With the roof tent on the back is down a little anyway so dropping the front isnt a huge issue i cant say i want it too feebal on the front. But im not a fan of just chucking any old springs on; i know from past experience (and advise) that genuine LR springs are better (after all the spend £billions of R&D)! Mike |
1st Jun 2008 10:45pm |
best thing to do is phone a 4x4 supplier with your requirements and they'll sort you out with the right set up.
mine are OME 761's (i think) |
2nd Jun 2008 7:05am |
Sorry i really disagree. Most of the suppliers dont know what they are talking about and source the springs from the same place. Some are worse than others - the best ones are the LR genuine springs. Mike |
2nd Jun 2008 5:17pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Try Famous Four - they know all about springs and shockers
2nd Jun 2008 7:36pm |
found a link to a site which explains a lot https://www.expeditionexchange.com/ome/indexsprings.htm
after checking the box mine are 751's |
2nd Jun 2008 8:34pm |
That site is a good site - been around a few years; they used to have a huge resource before a website change seemed to loose a lot.
Interesting read though. The thing with springs is Land Rover do spend some serious cash on this; ive never seen aftermarket suppliers spend this much - thus you always seem to get a change; land rover is taller, decreased travel (articulation) etc This is why ive built up a great deal of reluctance on none OE springs. Mike |
3rd Jun 2008 7:14am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Mine and SWMBO's both have OME 2" lift springs front and rear. Luvley smoother ride
5th Jun 2008 6:19pm |
