Home > Off Topic > Lister Junior stationary engines |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Try a local traction engine rally. They usually have a stationary engines exhibit.
...or buy a copy of Old Glory. Have you tried contacting Lister/Petter themselves? |
14th Apr 2013 4:46pm |
I may do but it depends on what needs to be done.
14th Apr 2013 4:47pm |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
As you are in Cornwall any good (old) boat yard will be able to point you in the right direction of where to get them re-metaled and then broached back to size. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
14th Apr 2013 5:01pm |
Falmouth Dockyard. A & P.
http://www.ap-group.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Apr 2013 5:12pm |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
I used to work on Canal boats, full of old Listers. If you have no joy, give me a shout, I'll see if I can help.
14th Apr 2013 7:18pm |
