Home > Puma (Tdci) > 2Q's.
RED-DOT
2Q's.
Are the front and rear washer jets the same, not the stem just the jet part? I bought the jet part and it seems reluctant to tap on.
Are the constantly rusting headlamp ring the same from TD5 to Puma? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #225702 9th Apr 2013 8:38am
GUM97
I'm pretty sure that the jets are Thumbs Up An engine to TDi for!
Post #225734 9th Apr 2013 9:41am
Re: 2Q's.
Yes.
Post #225736 9th Apr 2013 9:44am
JSG
Re: 2Q's.
blackwolf wrote:
Yes.
You can get stainless ones on eBay Thumbs Up John
2011 Tdci 110 CSW XS
Post #225758 9th Apr 2013 10:30am
And from Mobilecentre. No Guts, No Glory.
Post #225760 9th Apr 2013 10:51am
RED-DOT
Good info guys... Fitted the new jet with a tap from a rubber hammer and fitted chromed ring from GEMM Larbert. 30m max. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #225767 9th Apr 2013 11:49am
ZeDefender
Re: 2Q's.
The jets are a really tight fit Thumbs Up Tell someone you love them today because life is short.
Post #225768 9th Apr 2013 11:53am
RED-DOT
Not tight enough to stop them popping off when frozen. Quite handy the jet comes seperately now. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #225769 9th Apr 2013 11:57am
nakatanenga
Germany
NO! they are not the same on the inside! The rear one is shorter.
Stainless headlamp rings are available from us as well. WANTED:
SII or SIII in max 1.5k
Post #225770 9th Apr 2013 11:57am
RED-DOT
I only bought the twin jet part not the threaded part with the brass nut, I never knew the parts came split. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #225772 9th Apr 2013 12:02pm
nakatanenga
Germany
did not know that as well Sad WANTED:
Post #225773 9th Apr 2013 12:09pm
RED-DOT
Yes, genuine LR part too. I always felt separating the jet from the stub made it looser. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #225803 9th Apr 2013 3:46pm
K9F
I originally knocked mine off with a brush at tnhe jet wash. I stuck it back on with a smidge of marine sealant many months ago, seems to have done the trick as it's still there.
Thumbs Up Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #225804 9th Apr 2013 3:48pm
