Home > Td5 > TD5 starting problems |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Could be your fuel pump relay not switching due to low voltage while cranking.
How old is your battery? |
7th Apr 2013 9:55pm |
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 |
It's only a few month old, I changed that in case it wasn't getting the cranking amps off the old battery, incidentally when it's cranking the pump relay seems to click on and off but I don't know it that's normal
7th Apr 2013 10:00pm |
I had this problem a couple of years ago. If the relay's clicking while cranking then that is your problem. Try replacing the relay. If it still vibrates check your battery connections and add a new earth cable between the relays and the gearbox. |
7th Apr 2013 10:05pm |
Ok thanks ill give it a go
7th Apr 2013 10:09pm |
Should be a yellow relay.
7th Apr 2013 10:15pm |
Unbelievable, thanks Laurie, you were 100% right about the relays clicking on and off during cranking, it turned out that both the fuel pump relay and the heater plug relay were clicking during cranking so first of all I swapped the relays for some out of my van as they were the same but the problem was still there and as they both were doing it I figured it must be something else and re fitted the originals
Previously I'd read about the earth wire under the ecu near the relays being a problem but I'd cleaned it up and refitted it so I didn't think that was a problem until Laurie suggested running another earth, so I run another earth wire from under the ecu direct to the battery and hey presto...... No clicking relays and starts instantly! I even removed the earth straight away to prove it, Would you believe something as simple as that and best of all it's a free fix Thanks again for the info |
8th Apr 2013 12:24pm |
