![]() | Home > Td5 > Help with Spluttering TD5 |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
Fitted new injector loom and gasket, cleaned out the oil on the ecu side, waxoyled the engine bay and every plug got cleaned an dielectric grease blasted through. i will report back on results..
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 ![]() ![]() |
Thanks to Tucker and everyone.else here. I tried the turbo wastegate, and it was indeed pretty much seized. A bit of 3-in-1 oil, a few wiggles with the molgrips and it's sorted. Cost 2p! Excellent. Thanks again.
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
How much play should there be on this valve, i can move it about 1CM isn, but its hellishly loaded? JD |
Cleaned out the MAP sensor on the manifold with still no joy, next is the wastegate and MAF sensor.
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 ![]() ![]() ![]() |
Certainly sounds like the waste gate, I experienced all the symtoms desribed new loom, ECU plug off and cleaned, but still missing at the top end in each gear,
Eventually mine stared seriously misfiring and fortunatley managed to get back to our local garage who remedied the problem identified on their diagnostic gizmo as a siezed wastgate. A year down the road it's still fine pulls really well massive difference ![]() Get out the mole grips DRW I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and ![]() |
....How much play should there be on this wastegate valve, i can move it about 1CM ish, but its hellishly loaded?
JD 2008 TDCi 2.4 XS CSW |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
john....hang on send you a you tube link....
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Did mention waste gate, and post video 9 days ago in this post
![]() ![]() ![]() ![]() ![]() ![]() Andy |
LoL i never thought of looking for a you tube vid.....
![]() Mine does not have this much play ...http://www.youtube.com/watch?v=FyZ4zXPZOf8 So may still be stuck 2008 TDCi 2.4 XS CSW |
Thanks to everyone for all the useful info and videos i overcame my fear of breaking the wastegate and found it was jammed..
Well i think the splutter is gone, went for a drive and she seems to be pulling a lot better too. I got a new MAF sensor but once i replaced it i also gave the wastegate another push pull to find it was completely jammed up, so i sprayed a combination of GT85 and WD40 until it released and now all seems to be running sweet. Below is a list of replaced/fixed parts that got me to the end eventually. 1st was the cleaning out of the ECU which had oil sat in the red plug 2nd was the replacement of the injector loom which had oil ingress right through and the ecu has been cleaned out every fortnight since 3rd A new fuel filter and fuel return hose was replaced due to rust on the filter and leaking hose. 4th MAP sensor on manifold was removed and thoroughly cleaned out 5th MAF sensor replaced 6th the wastegate released as it was jammed Hope this can help someone else |
what is it that sticks with this wastegate, is it the valve bit or the section in the manifold, i am sure mine is sticking/stiff but not sure what to try to free up
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Where the thing piece of rod goes into the round actuator. it jams in the actuator, meaning the wastegate stays shut (or partially closed) and thus the boost can't be leaked off to keep within what its been set at, and then you get the overboost.
diesel_jim what sort of force is necessary to actuate this? If i put a pair of grips on the rod, with all my force i can move the arm about 1-2cm, does that sound right ?
You'll need grips to move it, yes.
Ian @ IRB did a youtube video clip showing it <----- |
