Home > Td5 > Help with Spluttering TD5
Page 3 of 3 <123
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Hope this video helps
Post #236595 18th May 2013 2:01pm
Porny
Site Sponsor
I really should re-do my quick video lol... Task for this week!
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #237076 20th May 2013 6:27am
johnnyd
I have watched your video numerous times, i need both hands on the grips to be able to move the rod, you seem able to move it with one, i don't know why mine is under such load?
JD 2008 TDCi 2.4 XS CSW
Post #237087 20th May 2013 7:03am
Porny
Site Sponsor
JD
I must have had my Weetabix lol...
If you need two hands either you have a actuator fault, or the waste gate is very stiff.
I would remove the heat shield and unclip the actuator from the turbo... and they try the actuator and waste gate independently of each other. The waste gate should move freely with no resistance at all. The actuator will require some force to move, but nothing excessive.
Ian IRB
Post #237106 20th May 2013 8:44am
ttuck3r
Second MAF sensor in 11 months, what the heck!
I did notice when removing the Sensor there was two burnt bugs caught in the mesh so im wondering if this could have been the fault...
Post #311048 23rd Feb 2014 8:29pm
ttuck3r
So i got hold of a Snap on ETHOS diagnostics system and plugged it in as i had full power until she hit 65 mph, there after it felt like hitting a strong wind head on which slowed me back down to 55 - 60mph and stayed there
once i got the fault code it was indicating wastegate
So started her up and went for a drive with the system plugged in when i noticed the air flow indicator was flat lining, i did another fault code check, this time indicating MAF sensor
So into Dingbro and bought a new MAF sensor, plugged it in started her up and now she powers all the way through. Moral of the story steer clear of 2nd hand MAF sensors..
Post #317981 21st Mar 2014 10:29pm
Page 3 of 3 <123
