Home > Technical > TD5 Leak
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
TD5 Leak
Hello i don't know what this is to do a search so i've taken a pic so someone can advise on leaking diesel i noticed the wet patch last week, and could this be a potential problem for my spluttering and difficult morning starts.
Post #225186 7th Apr 2013 12:35pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
My water sensor (the bottom black bit) was leaking a few weeks ago didn't cause any running problems but is cheap (about £15) to replace. The big canister it's attached to is the fuel filter, it could just be loose.
Post #225187 7th Apr 2013 12:40pm
ttuck3r
Thanks for that i will give it a twist.
Post #225190 7th Apr 2013 12:59pm
landy andy
Could also be a porous filter head. Not uncommon and not cheap.
Sorry
Andy
Post #225211 7th Apr 2013 3:31pm
ade666
United Kingdom 2003 Defender 110 Td5 DCPU Belize Green
Tucker, might be teaching granny to suck eggs but mine was leaking, popped to my mates garage and when we tightened it real easy like it snapped off and launched diesel everywhere. My filter looked like yours and had corroded through
Post #225223 7th Apr 2013 4:15pm
miket
Similarly to Ade666, I've had a fuel filter corrode and start to leak - easy to change though It's been a long winter with a lot of salt about...
Post #225261 7th Apr 2013 6:05pm
ttuck3r
Thanks you gents i will be giving it a tap and tightening up as soon as my new one arrives...
Post #225279 7th Apr 2013 6:34pm
Phil_C
2010 Defender 90 Puma 2.4 HT Galway Green
I'd be inclined to replace both - I had a similar problem with my TD5 Disco where the water in the sensor had frozen and caused a slight crack in the casing. Fuel filter is easy to replace and the water sensor the same - ten minute job, - P 2000 TD5 Disco II, front and rear winches, 2" lift, ARB bumper etc.etc. --
2010 TDCi Puma 90 HT - Bulkhead removal kit, Ashcroft front and rear lockers, Andersons front and rear, Warn XD9000i winch, battery split charge system, Patriot full roof rack. OME Suspension.
2013 Freelander II GS - Factory standard
Post #225977 9th Apr 2013 11:37pm
ttuck3r
Well i received my new filter cleaned up all the surrounding areas and replaced my filter, did a purge and this is what its revealed.
Now how do i go about fixing this please, does it mean replacing the line or can you buy just the plug?
Post #226407 11th Apr 2013 6:14pm
ttuck3r
All sorted, i cut the plug off with the red rubber jacket as thats where the leak was, and replaced it with a short pieces of fuel line.
Went out for a nice drive and all is well..
Post #226845 13th Apr 2013 1:47pm
