Home > Puma (Tdci) > Roof Trim Studs
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Roof Trim Studs
Is there an easy way to remove them without them breaking? I need to get the roof lining down to run some cables but I don't want to cause any damage in the process.... 2013 Aintree Green 110 Station Wagon SX
Post #225065 6th Apr 2013 2:42pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I use a claw hammer and gently lever them out. Place something flat and rigid between the hammer and lining though. Thumbs Up
Post #225067 6th Apr 2013 3:09pm
Green Machine
As Rusty says, a claw hammer will work. I have a trim removal tool, but it's basically the same idea. You just need to apply equal pressure around the head of the fixing and pull it out straight to prevent them from snapping. If you stick a screwdriver under one side and lever them out they tend to snap due to the uneven loading. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #225069 6th Apr 2013 3:13pm
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
Old fork with middle prong bent / broken out of the way.
Make sure it's and old one 0 sunday best sterling silver doesn't go down well - but is stronger! TY&GN
10 years in a WOLF, WIMIK and Snatch and this is all I have to show!
Post #225119 6th Apr 2013 7:07pm
