Home > Puma (Tdci) > Brake pad wear
Page 2 of 3 <123>
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
I know it's not quite the same, but I got 10 years & a 100k miles on the front pads on my 200Tdi 90! And proud of it!
Post #224419 3rd Apr 2013 6:52pm
ericvv
On my 2009 110 the rear pads were changed at 40k km. Today the truck has 61k km, and the original front pads still are ok.... I don't understand this because think the front brakes suffer more than the rear. With most cars the front disks are larger than the rear disks for good reason. Question Question Question You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #224424 3rd Apr 2013 7:09pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Yes, the front discs are bigger, but the front pads are bigger also. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #224447 3rd Apr 2013 8:49pm
dgardel
Italy
Change mine at 70.000 km Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #224489 4th Apr 2013 7:44am
smb
Just had to change my original rear pads yesterday at 37,500miles.
Towing, and what you are towing does have a major impact on rear pads as the braking has to be biased to stop jack-knifing.
I wouldn't rely on the dealer sorting it out as they are more than likely going to stick to the story they have already given you. If you can do it, it would be an idea to try and do some heavy towing up and down hills with 'gentle' braking. After a 1000-2000miles take the pads out and measure the thickness of the pads to see the nature of the wear. They will wear slightly more on the front end, but shouldn't be too much of a difference. Depending upon what you find in all the measurements the information should enable an accurate diagnosis.
Armed with physical evidence and an independent report your dealer should struggle to get out of it if it is a LR problem.
Post #224540 4th Apr 2013 10:10am
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Brake whistle sound!
Once mine changed at 20K miles on the clock both front and rear with mintax but noticed specially the rear one was badly worn even cutting the disk. So had to re-phase it. Then after another 15k miles found only rear one has worn with metal to metal scenario. This time couldn't afford the mintax so fixed it up with a taiwan rear set. Now i am getting that LR typical braking whistle noise from the rear and guess due to the odd set fixed but without compromising the braking perfomance. I will see how long I can live with it! Very Happy Very Happy
Post #225237 7th Apr 2013 5:12pm
Grockle
45k and still on original pads all round. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #225385 8th Apr 2013 10:34am
Fitted what I believe to be the second set of rear pads to mine last week at 116k miles.
Post #225419 8th Apr 2013 12:37pm
JWL
Just fitted a new set to the front of mine, last set did 40k miles only reason I've put a new set in is because the inner pad on the offside was down to the metal, the other was just about half worn where as the nearside were both half worn. I put down some of the uneveness of wear between wheels down to the traction control but not on the same caliper, that's sticking pistons.
Post #225427 8th Apr 2013 1:30pm
pwgg
South Africa 2007 Defender 90 Td5 SW Chawton White
pad wear
Join the brake pad club guys. I am on my second Puma HCPU 110 same story with brake pads specifically the rear set. Farming my average speed is about 5 kph, water and mud very little, on average I replace the rear sets at about 4500km, fronts every 20000, unacceptable to me as my 90 and Freelander just go on and on. Was told by a dealer and LR South Africa to service daily as I was abusing the vehicle. Took umbrage and made a fuss, LR SA changed the booster and master cylinder. I managed 16000km on a harder compound, so now I just live with it........... Bow down pwgg
Post #225985 10th Apr 2013 6:19am
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Rears changed at 50k km's, fronts still original at 95k km, very little towing, though.
Post #226038 10th Apr 2013 12:20pm
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mine was just replaced all round last week, 49000km.
Post #226051 10th Apr 2013 2:10pm
pwgg
Well you guys are lucky. In this district 4 Defender 110 HCPU have the same problem, we just suck it up and replace them but one guy has already dumped the brand.. pwgg
Post #226078 10th Apr 2013 4:16pm
Caterham
I've not looked yet but I'm getting prepared to replace all pads soon - I'm at 45k miles.
Post #363043 8th Oct 2014 8:08am
RED-DOT
Just done mine @ 7yo and 29K and the old ones were as good as the new ones although the rear inside pad was VERY tight in the caliper. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #363277 9th Oct 2014 6:33am
Page 2 of 3 <123>
