Home > Technical > Window not working
bcarlin
Window not working
Hi I am getting my new 110 at the weekend but the drivers window is not working. Anyone Had issues with them before ?
It's a 2008 puma. Are the switches known to fail or is there a relay somewhere.
Post #224410 3rd Apr 2013 6:39pm
bob neville
My money is on the cables that run in the rubber trunking from the door frame to the door being damaged.
They have been known to cause problems.
You should be able to investigate and repair easily.
2013 Defender 90 CSW - sold
Post #224413 3rd Apr 2013 6:49pm
bcarlin
Thanks for the tip Thumbs Up
Post #224420 3rd Apr 2013 6:53pm
landy andy
As above. Cable from post to door. When you pull the rubber sleeve back it will be one of the two fat wires. Give them a good pull.
Andy
Post #224422 3rd Apr 2013 7:02pm
110SEB
I had a bust motor on the driver's door. Just needed replacing. It had just burnt out.
I don't think it cost very much to replace. I didn't do it myself.
Post #224560 4th Apr 2013 11:30am
spudfan
Ireland
Wife just told me that the driver's window on our 2008 Puma is not working. Must check those cables. Thumbs Up 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #224562 4th Apr 2013 11:46am
spudfan
Ireland
Managed a temporary reair as the wife was heading out. Could not get the rubber sleeve pared back far enough so I had to slit the rubber sleeve underneath to gain access. Seems it was a break in a previous repair. The break is at the very bottom where the rubber sleeve enters behind the door trim. Does'nt seem to pull forward from the door. Is the only way of accessing this to prise away the bottom of the door trim? I would like to make a better repair and push the join in behind the door trim to stop any strain on the repair. 1982 88" 2.25 diesel
Post #224579 4th Apr 2013 1:21pm
bcarlin
Picked up the 110 tonight Very Happy popped the door card off and undone the rubber from the bulkhead and pulled the red wire out Shocked Fed a new piece of wire through and crimped it up- it now works Bow down Only a 20 minute job. Thanks for the tip
Post #224671 4th Apr 2013 7:49pm
