Home > Wheels & Tyres > Wheel balancing weights
WarPig
I took my caravan wheels to be balanced today and whilst I know nothing at all about wheel balancing, I was surprised how many weights needed to be applied. I was wondering if fewer but heavier weights could have been used instead of loads of lighter ones? Or is this the way its done?
Heres one of the wheels, which as you can see has had 100(grammes?) of weight applied....
Post #224058 2nd Apr 2013 10:08am
Slim line strips come in 60g loads made up as you can see of 5g & 10g (some strips come as 5gs still 60g total)
Yes there are bigger single weights out there however these can cause clearance probs
Me I'd spun the tyre first less weight maybe required unless they had already done that
Post #224065 2nd Apr 2013 10:42am
WarPig
They did first put the wheels on their balancing machine, with the first wheel that said it needed 70g adding. The wheels hadnt been previously balanced. Im assuming the caravan could have been shaking like mad without me knowing?
The weights are just stuck on with a self adhesive backing, had I known I would have cleaned the rims for a better bonding. Are they likely to hold firmly in place or should I keep an eye on them incase they fall off??
Post #224073 2nd Apr 2013 11:07am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Nah, you should be fine with those weights as long as the they cleaned the wheel before applying them. Centrifugal force also helps the adhesion process. I've got the same on my alloys but in greater quantities, doesn't seem to matter what I throw at the wheels, the weights still stick firm Smile
Post #224075 2nd Apr 2013 11:13am
WarPig
Ive just had a closer look at the wheels and it does look like they wiped the area of the rim first Smile
If I did notice that some had fallen off could I just buy some more and replace them myself, now I know exactly where they are positioned. Or is that fools talk? Shocked
Post #224077 2nd Apr 2013 11:18am
TJ101
Worth putting some tank tape over the weights,,
Very much doubt they were balanced from new,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #224078 2nd Apr 2013 11:32am
WarPig
Is tank tape the same as duct tape?
Post #224080 2nd Apr 2013 11:56am
TJ101
That will do the job,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #224084 2nd Apr 2013 12:10pm
WarPig
Thanks Thumbs Up
Post #224086 2nd Apr 2013 12:15pm
TJ101
No so much with stick on weights,, but seen a clip on weight make a mess of a wing top !!! Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #224088 2nd Apr 2013 12:16pm
The tape will throw the the wheel out however its a trailer so at 60MPH its not that much in reality
Post #224095 2nd Apr 2013 12:52pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Didn't realised people bothered balancing caravan wheels Shocked
Post #224097 2nd Apr 2013 1:02pm
TJ101
Always tape ours certainly on the rally cars !!
will never get that close on balanceing to make any difference the tape would have California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #224099 2nd Apr 2013 1:13pm
Rolling with laughter Thumbs Up
Post #224100 2nd Apr 2013 1:24pm
WarPig
Most folk dont, even the manufacturers say you dont need to. But best advice is to get them balanced anyway as the caravan will otherwise surely shudder? How can it not? Especially as one of my wheels needed 100g of weight added.
There were horror stories a couple of years ago of Bailey caravan wheels detaching during towing Shocked Not sayong it was due to wheel balancing, I think it was faulty wheel studs. But an unbalanced wheel isnt going to help.
Post #224105 2nd Apr 2013 1:45pm
