Home > Puma (Tdci) > Rough at startup and smoke
Page 2 of 2 <12
aabruce
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Check hoses as well. Any induction leak will cause rough running when cold and sometimes white smoke. Check circlips are fully tight. Alex
Post #161734 13th Aug 2012 8:59pm
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
My God lads, I've spent the past few evenings reading through this section of the site and this thread has hit the nail on the head with my Puma Very Happy We have had a cold snap over the past few days andIhave really noticed my Defender (2007) doing this. Rough on start up and smoke for a few seconds. I will give the 2SO a go before I get the spanners out Laughing
How much should I add to each fill?
Thanks Again for coming to my rescue Thumbs Up
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #222718 27th Mar 2013 9:24pm
Egghead
Exactly the experiences I've been having over the last few days of cold. I had her serviced a few weeks back so I'm putting it down to general Land Rover behaviour. Once going she's still bloody wonderful but it puts a little pause in my heart when I start her up for the first time that's all. The blueish smoke is not prolonged and the sluggish startup is not really any worse than myself getting out of bed on such a morning Thumbs Up
Post #222727 27th Mar 2013 9:42pm
dgardel
Italy
Check all the glow plugs..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #223091 29th Mar 2013 12:23am
Egghead
Exactly what a friend of mine said. Bow down
Post #223159 29th Mar 2013 12:07pm
BigWheels
Same problem here. Running on Sainsbury's diesel. I switched to Esso Super Diesel & problem gone. Much better at cold running, smoother, less rattles & resonance, better at low rpm traffic crawling as well. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #223172 29th Mar 2013 12:59pm
My 07 Puma used to do this. Since installing a BAS no-EGR remap it doesn't do it anymore, and also starts more promptly and smoothly, without smoke, and runs far better.
Also goes like stink and is much more fun to drive!
Post #223228 29th Mar 2013 5:24pm
mick
Mine does it when it's below 5 degrees rattles it bits off even with a new Egr must be some thing to do with the electronics a few others have told me there's do it as well. Thumbs Up
Post #223257 29th Mar 2013 6:38pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Mine has just come back from warranty work. This was one of the issues-had a "software update" no different. Fires on about 3rd turn, smokes then clear.
Post #223365 30th Mar 2013 7:18am
rossy
John
Hi John
you add 5ml of 2SO per litre of diesel. It must be a mineral JASO FB spec (not semi synthetic) - in fact the cheapest you can get. If you want to know why do a google search and there are thousands of posts on this subject ! Carplan motorcycle 2so from Tescos or B&Q is only € 6 for a litre bottle. Seems to be the cheapest.
Post #223438 30th Mar 2013 1:12pm
John110
Thanks Rossy, I'll give that a go and see how I get on Very Happy
Regards
JOhn For those who understand, no explanation is needed...
Post #223992 1st Apr 2013 7:21pm
Photoguy1510
New Zealand 2013 Defender 110 Puma 2.2 SW Orkney Grey
Hi John
what will happen if you use semi synthetic 2so? First time I read this, will be the day I went and added 2so for the first time in my appliance. Shocked I picked it as it stated low ash with cleaner to keep exhaust cleaner than traditional mineral based 2so. Also went for the most expensive I could get my paws on, lucky I only have it for another 5 days till the defender is ready for pickup. Rolling with laughter was told to mix it 400:1 but 5ml/l (200:1)is double that. On another forum they recommended using marine 2so as it has rust inhibitor extra, meant to be good for those sticking valves. I'm not a mechanical engineer so just interested and hoping I did not ruin a fairly ok toy motor today. 2013 Orkney Grey 110 SE on order should be here on 20/04
Post #224772 5th Apr 2013 7:39am
Page 2 of 2 <12
