Home > Puma (Tdci) > Dual Batteries |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 |
Has anyone found a decent step by step how to for setting up dual batteries? I'm in the planning phase and what to get it right first time 2013 Aintree Green 110 Station Wagon SX
28th Mar 2013 8:41am |
Any good?
http://www.defender2.net/forum/topic17537.html?highlight=dual http://www.defender2.net/forum/topic17747.html?highlight=dual http://www.defender2.net/forum/topic11113.html?highlight=dual Speak to or 'pm' Brendan (Leeds on the forum) would be my advice and first pot of call! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Mar 2013 10:12am |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
If you prefer a ready-to-fit system we ave a dual battery tray including BANNER running bull AGM batteries and National Luna or IBS solenoid with monitors
http://nakatanenga-tours.de/shop/article_N...SDEF-NL%26 WANTED: SII or SIII in max 1.5k |
28th Mar 2013 11:24am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2648 |
The guys in SA are starting to switch from the National Luna type setups to CTek setups. This allows them to have a setup with charges the Aux battery from both the vehicle's alternator and a solar source.
Something similar to this setup: Click image to enlarge the only downside of the Ctek setup is that you cannot put both batteries 'online' to help start the engine or use the winch -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
28th Mar 2013 11:45am |
Excellent info guys.
I'm looking at Dual Odyssey PC1500s as I already have one, using the Merlin SmartGuage to manage the cahrging - just got to figure out where to put the display, a BlueSea 12way Fuse Block and front and rear Anderson Connectors. 2013 Aintree Green 110 Station Wagon SX |
28th Mar 2013 2:47pm |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
If you struggle with a location for the display one idea i have seen is behind the sun visor. Flip it down have a read, link the batteries together etc. then just flip it back up out of the way again.
28th Mar 2013 8:22pm |
28th Mar 2013 8:23pm |
Warden - I'm not far from you and have a twin PC1500 + bluesea installation.
Tim at MobileCentre sells complete kits. Buying the batteries, controller and fuse box is the easy part, you also need the cables and connectors and tools to make them up. PM me if you'd like to meet up or email some photos |
29th Mar 2013 7:46am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
I too have the twin Odysey set up from Tim at Mobile Centre but opted to make up my own cables.
There's a few pics on my FCX130 thread |
29th Mar 2013 7:55am |
