Home > Puma (Tdci) > Dual Batteries
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Dual Batteries
Has anyone found a decent step by step how to for setting up dual batteries? I'm in the planning phase and what to get it right first time 2013 Aintree Green 110 Station Wagon SX
Post #222797 28th Mar 2013 8:41am
K9F
Any good?
http://www.defender2.net/forum/topic17537.html?highlight=dual
http://www.defender2.net/forum/topic17747.html?highlight=dual
http://www.defender2.net/forum/topic11113.html?highlight=dual
Speak to or 'pm' Brendan (Leeds on the forum) would be my advice and first pot of call! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #222828 28th Mar 2013 10:12am
nakatanenga
Germany
If you prefer a ready-to-fit system we ave a dual battery tray including BANNER running bull AGM batteries and National Luna or IBS solenoid with monitors
http://nakatanenga-tours.de/shop/article_N...SDEF-NL%26 WANTED:
SII or SIII in max 1.5k
Post #222853 28th Mar 2013 11:24am
Naks
The guys in SA are starting to switch from the National Luna type setups to CTek setups. This allows them to have a setup with charges the Aux battery from both the vehicle's alternator and a solar source.
Something similar to this setup:
the only downside of the Ctek setup is that you cannot put both batteries 'online' to help start the engine or use the winch --
Post #222860 28th Mar 2013 11:45am
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I used the National Luna Battery Box and I have it in the back so it's close to the fridge. I run 16mm2 cables from my main battery outside and back in at the back. My Monitor is up front.
This setup is nice cause the battery is portable and its easy to remove when I need more space or need it somewhere else away from the landy. I also dont like the (2 battery) setup in the battery box. Not really enough space for my comfort to hold 2 batteries safely.
Another plus is that you can run a solar cell as well when the solenoid disconnects when the car is off. You might just have to do the changeover with a manual switch.
Post #222868 28th Mar 2013 12:06pm
TheWarden
Excellent info guys.
I'm looking at Dual Odyssey PC1500s as I already have one, using the Merlin SmartGuage to manage the cahrging - just got to figure out where to put the display, a BlueSea 12way Fuse Block and front and rear Anderson Connectors. 2013 Aintree Green 110 Station Wagon SX
Post #222901 28th Mar 2013 2:47pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
If you struggle with a location for the display one idea i have seen is behind the sun visor. Flip it down have a read, link the batteries together etc. then just flip it back up out of the way again.
Post #223011 28th Mar 2013 8:22pm
pope10001
Post #223012 28th Mar 2013 8:23pm
Warden - I'm not far from you and have a twin PC1500 + bluesea installation.
Tim at MobileCentre sells complete kits. Buying the batteries, controller and fuse box is the easy part, you also need the cables and connectors and tools to make them up.
PM me if you'd like to meet up or email some photos
Post #223109 29th Mar 2013 7:46am
I too have the twin Odysey set up from Tim at Mobile Centre but opted to make up my own cables.
There's a few pics on my FCX130 thread
Post #223111 29th Mar 2013 7:55am
