Home > Td5 > TD5 cruise control kit
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Anybody on here making one yet for the TD5? I see terrafirma are doing one but i dont know how much it costs??
Post #20815 28th Dec 2009 12:09am
Get yourself a few lengths of cable,some switches and read all about it here <----
Post #20850 28th Dec 2009 9:44pm
nickh90
England 1989 Defender 90 V8 Petrol SW Auto Java Black
Someone fitted it to my TD5 90 before i bought it, but when they changed to the discovery ratios it no longer worked other than in 4th gear!
Be aware as I am not aware of a fix!?
Post #22154 15th Jan 2010 9:32am
Apparently Pete was (in some other posts on here, or maybe it was LRA) attempting a fix to this problem. either he or Porny should be able to fix it.
Post #22199 15th Jan 2010 9:56pm
Zinke
Whats the reason for this?
Ive got standard gearing because i tow a lot but interested to know why it makes a differents!!
Post #22206 16th Jan 2010 12:15am
Apparently the Td5 ECU has pre-programmed limits for stuff, and it knows that say, for 70mph it has to be doing 3500rpm (as an example, i don't know what the revs are for that speed)
Now, if you fit an overdrive or a 1.2:1 t/box, (as i have), then you could be doing 70mph at, i don't know, 3000rpm?, so the ECU will think "hmmm, that's outside of my parameters as a Td5 with 1.4:1 gearing should be revving at 3500rpm.... something is wrong" and won't let the cruise work.
Whether this works on all ECU's i'm not sure, and whether the above is 100% accurate, again not sure, but that's the way i understood it when Pete was talking about it on here, and when i've chatted to Porny.
Post #22213 16th Jan 2010 8:11am
Zinke
That makes sense.
Thanks.
Post #22216 16th Jan 2010 9:21am
jools
United Kingdom 2003 Defender 90 Td5 XS CSW Zambezi Silver
Fitted mine over the weekend.....
Tip of the day
The instructions say:
"From inside the engine bay......feed the 2 core wire through the bulk head.....
From inside the cab, find the end of the 2 core wire and feed it safely......."
Yeah right!!! - It just coils itself neatly out of sight!! Rolling Eyes
So my tip of the day - Use some nice brightly coloured nylon strimmer cord to feed through the bulk head. Its quite stiff and doesn't coil itself away - and a nice bright green in my case was easy to spot. Once its through and you can locate it you can then tape the 2 core wire to it and pull it through - perfect. Thumbs Up
Anyway - all fitted - been on a test drive and seems to behave exactly like my Freelander CC did
Obviously no light on the dash to tell you that its engaged (like the FL) - but a slight touch to the brake, clutch or the button itself and it disengages
Taking the Landie to work tomorrow - so will give it a run chugging down the A38 somewhere between 55-60MPH
Jools 2003 90 XS SW
Support Devon & Cornwall 4x4 Response - www.buy.at/dc4x4
Post #31419 4th May 2010 7:53pm
Zinke
Glad my kit worked well for you, i might just include your in tip in future instructions!
Pete.
Post #31558 6th May 2010 12:03am
CarMan
Zinke's kit is great - well worth doing
Post #46673 29th Nov 2010 9:42pm
pom
is there a kit for the puma ?
pom
Post #46704 30th Nov 2010 9:02am
Naks
Post #46709 30th Nov 2010 9:36am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
pom
Yes Whistle
Post #46783 30th Nov 2010 6:19pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Aha, where can we find more info on that Question Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #56046 1st Feb 2011 6:52pm
110SEB
I was expecting to read a topic about one of these resting against the throttle pedal...
Post #56113 1st Feb 2011 9:54pm
