Home > Maintenance & Modifications > Plasti-kote spray paint
WarPig
Ive read of a few folk on here using Plasti-kote Metal Protekt spray paint on their rear cross members etc. So is this just normal spray paint or is it a kind of plastic coating?
And what prep work would be needed? I'm wanting to touch up a few areas such at tow bar slider, bike rack etc that have a few small patches of surface rust. Would I need to use their primer first?
Post #221266 22nd Mar 2013 9:31pm
mikeh501
Re: Plasti-kote spray paint
looks like normal rattle can paint to me. id rub down your crossmember and then use red oxide primer, then topcoat it with whatever takes your fancy, including this stuff.
Post #221281 22nd Mar 2013 10:28pm
K9F
I have used Plastikote on several items including window catches, A-bar brackets, Patriot roof rack brackets etc...I have also used it's own primer. Several coats can be applied in quick succession with only 15 minute intervals between applications. With good coverage and preparation you will get a good durable finish. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #221283 22nd Mar 2013 10:39pm
I'd rub down and clean any grease or muck off of it. Use E-tech acid etch primer. If you want a really glossy finish sand down the primer lightly with wet and dry paper (fine) or if not so worried by the glossy side leave it. I'd use Simoniz gloss black for base 2 coats and 2 coats of Simoniz clear lacquer to finish it all off. All of these items are available for E-bay and not too expensive. All in £15 - £20 I suppose.
Up to you what you use really. It's how it's used and the prep that goes into it that counts.
Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #221286 22nd Mar 2013 10:55pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I recently did my front bumper with Plasti-kote. I used the zinc primer first as this was recommended on their website for areas of heavy corrosion.
The finish is excellent, but ignore their advise on preparation... I sanded down the outside with a belt sander and got rid of most of the existing paint and rust. Obviously I couldn't do this on the inside so just used a wire brush and some wet/dry paper. What I found was that the primer worked well on the outside, but actually made some of the old paint peel off in the inside. This may just be a property of the zinc primer, but the point is make sure the surface is well rubbed down.
Post #221392 23rd Mar 2013 2:01pm
WarPig
Excellent, many thanks. Ive applied the Plastikote Metal Proteks directly to some new parts, but for the older scratched parts Ill get some primer to apply first.
Thumbs Up
Post #222022 25th Mar 2013 3:50pm
K9F
Ironically I'm spraying the rear wheel security plate for my Landy today with Plastikote...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #222023 25th Mar 2013 3:52pm
WarPig
Ive just done my new 2 pin adjustable tow slider, along with Maxxraxx bike rack mounting plate.
So what makes Plastikote different from any other spray paint. Or isnt it?
Post #222036 25th Mar 2013 4:25pm
x-isle
I don't think it's any different, just a brand name. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #222038 25th Mar 2013 4:34pm
WarPig
Dont say that, I want to hear its something special Sad
Post #222041 25th Mar 2013 4:38pm
x-isle
Smells nice?....... Mr. Green Craig Rogers
2007 Puma 110 XS
Post #222043 25th Mar 2013 4:39pm
WarPig
Yeh, it does actually Very Happy
Post #222044 25th Mar 2013 4:41pm
K9F
Other people must think so too. At the self checkout I had to get the assistant to negate the 'over 21' age request so I could pay for it.
At nearly 52 I felt quite chuffed I'd been asked for proof of age. Even if it was by a machine...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #222053 25th Mar 2013 5:01pm
Mal - You should actually try being 21 and trying to buy some. You get treated like a criminal even with ID. Evil or Very Mad Saying that depends on the checkout operator if it's a human one and not an automated one. Does my head in!
I just buy mine on-line and avoid the hassle. Mr. Green TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #222056 25th Mar 2013 5:04pm
WarPig
Thats because all 21 yr olds sniff solvents Whistle
Post #222059 25th Mar 2013 5:08pm
