Home > Technical > Battery drain??? |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
get an ammeter and start tracing current usage whilst your engine is off is what id recommend as a layman.
25th Mar 2013 12:54pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Maybe skytag is draining it!
25th Mar 2013 1:17pm |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
Maybe. Friend of mine had to regularly switch off tracking when cold as it was draining his battery overnight. I am talking about 20 below zero though. Janusz www.yahodeville.com |
25th Mar 2013 1:36pm |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 |
Thanks for input chaps, checking the individual circuits was my next step (just sat at work plotting my attack ) but what I was really looking for was any tips/insight on common pitfalls like imobiliser, common wiring problems etc. etc.
and of course it could be the skytag tracker itself I'm not ruling anything out at this stage, just a bit frustrated as I've got nothing on here at work and a problem on my car that needs sorting that I can't do anything about until tomorrow Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
25th Mar 2013 2:14pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Can't see it being the tracker, they only draw milliamps.
How old is your battery? mine did this [although battery seems fine] a replacement battery solved it Guns and Landrovers .... anything else is irrelevant. |
25th Mar 2013 3:33pm |
About 4-5 months old Optimists say the glass is half full..
25th Mar 2013 3:38pm |
With engine running, how much voltage does your meter show then?
It's also worth getting a load test carried out on battery, not uncommon for batteries to fail [even new ones] Guns and Landrovers .... anything else is irrelevant. |
25th Mar 2013 3:40pm |
A little over 14v Optimists say the glass is half full..
25th Mar 2013 3:44pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Just checked with Skytag for you and as DaveH has said the unit only pulls milliamps.
I'm with DaveH on his diagnosis, get the battery checked out or swap with your leisure battery |
25th Mar 2013 3:49pm |
Many thanks for that, much appreciated, I was considering doing that but wasn't sure if a leisure battery would be up to it .... I don't really want to risk damaging the leisure battery, I think I'll try and locate the problem Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
25th Mar 2013 3:59pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
I've had a similar problem... Pm me to discuss as you may have wired it the same way as mine... Which could be your issue..
Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
25th Mar 2013 9:19pm |
Tim, Did have a chuckle at your forum name especially considering the current thread you're posting on. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Mar 2013 10:09pm |
