Home > Technical > Battery drain???
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Battery drain???
G'day chaps, been getting a lot of Skytag low battery alerts lately, I have a fairly new battery fitted (less than 6months) and
I first thought that my heatshot was pulling battery down so I moved that over to the leisure battery to see what happened. 2 weeks later, another alert, my alternator appears to be charging fine. When I switch the car on it shows between 10-11v on my battery meter which I know should be higher, where should I be looking next? What else could be dragging the battery down (it does appear to do it more when the weather is very cold like now)
Mike Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #221926 25th Mar 2013 12:07pm
mikeh501
get an ammeter and start tracing current usage whilst your engine is off is what id recommend as a layman.
Post #221943 25th Mar 2013 12:54pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Maybe skytag is draining it! Laughing
Post #221949 25th Mar 2013 1:17pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Maybe. Friend of mine had to regularly switch off tracking when cold as it was draining his battery overnight. I am talking about 20 below zero though. Janusz
www.yahodeville.com
Post #221961 25th Mar 2013 1:36pm
taffrican
Thanks for input chaps, checking the individual circuits was my next step (just sat at work plotting my attack Very Happy ) but what I was really looking for was any tips/insight on common pitfalls like imobiliser, common wiring problems etc. etc.
and of course it could be the skytag tracker itself Whistle I'm not ruling anything out at this stage, just a bit frustrated as I've got nothing on here at work and a problem on my car that needs sorting Big Cry that I can't do anything about until tomorrow Big Cry Optimists say the glass is half full..
Post #221977 25th Mar 2013 2:14pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Can't see it being the tracker, they only draw milliamps.
How old is your battery? mine did this [although battery seems fine] a replacement battery solved it Guns and Landrovers .... anything else is irrelevant.
Post #222011 25th Mar 2013 3:33pm
taffrican
About 4-5 months old Shocked Optimists say the glass is half full..
Post #222014 25th Mar 2013 3:38pm
Dave-H
With engine running, how much voltage does your meter show then?
It's also worth getting a load test carried out on battery, not uncommon for batteries to fail [even new ones] Guns and Landrovers .... anything else is irrelevant.
Post #222017 25th Mar 2013 3:40pm
taffrican
A little over 14v Optimists say the glass is half full..
Post #222018 25th Mar 2013 3:44pm
Just checked with Skytag for you and as DaveH has said the unit only pulls milliamps.
I'm with DaveH on his diagnosis, get the battery checked out or swap with your leisure battery
Post #222020 25th Mar 2013 3:49pm
taffrican
Many thanks for that, much appreciated, I was considering doing that but wasn't sure if a leisure battery would be up to it Shocked.... I don't really want to risk damaging the leisure battery, I think I'll try and locate the problem Thumbs Up Optimists say the glass is half full..
Post #222027 25th Mar 2013 3:59pm
Morepower
New Zealand
I've had a similar problem... Pm me to discuss as you may have wired it the same way as mine... Which could be your issue..
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #222169 25th Mar 2013 9:19pm
K9F
Tim,
Did have a chuckle at your forum name especially considering the current thread you're posting on. Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #222188 25th Mar 2013 10:09pm
