Home > In Car Electronics > 2.2 90 Base spec headunit install |
Plodster Member Since: 24 Mar 2013 Location: UK Posts: 22 |
Hi all,
New to the forum (posted in new members) but wanted to get straight in with a question: I've got the base spec (with a couple of options - dealer upgrades) and obviously want to pop a head unit in. A little research so far seems to have revealed nothing about this really, with "radio preparation" in place, I have located the connector used for the LR head unit but it is not ISO layout......... Does anyone know anything about this and which connector converts this LR connector to ISO? The Transit one looks similar but just wanted someone to confirm if poss. Peter Hmmmm, thats not mud.... Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
24th Mar 2013 7:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20538 |
Hi & welcome to the site. Perhaps the two photo's of mine below I have added may help you out a little. Also regarding your Head Unit details I would recommend you have a look Here
Click image to enlarge Click image to enlarge No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Mar 2013 8:04pm |
Thanks for that, unfortunately I don't have any ISO connections, I have a single, multi-pin female plug with a red centre. Pics to follow but wondering if anyone else has popped a HU into a base spec def....... Peter Hmmmm, thats not mud.... Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
24th Mar 2013 8:06pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Peter- i have a base spec model and fitted a HU in no problem at all, all the relevant wires are behind the dash and sometimes are taped up CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
24th Mar 2013 8:12pm |
Chris - I was going to recommend you and yours but I thought you had such little issues that you had ISO connectors in yours like mine. (Which you obviously did in the end) No Guts, No Glory.
24th Mar 2013 8:17pm |
What I'm faced with when I undo the tape with the aerial plug.......
Click image to enlarge Hmmmm, thats not mud.... Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
24th Mar 2013 8:49pm |
That red piece is just an insulated insert by the look of it. It should come out. There should also be another connector like that somewhere in there. The wires from the connector and their colour would help also in determining whether it's power / earth feeds or speaker wire feeds. No Guts, No Glory.
24th Mar 2013 8:52pm |
whats that I recon there will be an adaptor from that to the standard older type one mate just give it a google CSK Automotive
24th Mar 2013 8:53pm |
I'll pop back out and photograph wire colours but no other connectors available or loose in the dash...... Hmmmm, thats not mud.... Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
24th Mar 2013 8:54pm |
Haha, I was worried someone would say that! I have spent the afternoon hunting all over Google and alsorts of forums and audio sites, just can't find anything like it. Hmmmm, thats not mud.... Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
24th Mar 2013 8:56pm |
There's an even harder way than an adaptor but I wouldn't recommend it. Maybe your only option though if nothing turns up as being available on the market as an adaptor. No Guts, No Glory.
24th Mar 2013 8:59pm |
I was trying to avoid that option. Damn, looks like I'm breaking out the soldering iron again! Hmmmm, thats not mud....
24th Mar 2013 9:00pm |
I'll have a look for you later and see if there is anything available for what your looking for. No Guts, No Glory.
24th Mar 2013 9:02pm |
That would be spot on if you could please! Hmmmm, thats not mud.... Current: Defender 110 HD Utility (Special Vehicles) Freelander 2 HSE BMW E23 735i Ex: 2013 Defender 90 2.2 1998 Discovery 300TDi 1972 Series II 2.25 1980 Series III 2.25 |
24th Mar 2013 9:03pm |
