Home > Technical > Does your defender
AndrewS
Does your defender
lock itself.
On a number of occasions our defender has locked itself with the keys inside. Luckily for me we had the spare keys with us. Just wondering if anyone else has had this issue.
Post #22128 14th Jan 2010 9:06pm
Eduardo
Shocked Shocked
Never happened to us
But anyway, as a safety measure we never leave the keys inside.
Cheers Eduardo
Post #22129 14th Jan 2010 9:09pm
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
If I ever leave the key inside, I always leave a window open. About 20 years ago, the doors locked themselves on a BMW I had, with the keys inside. I can still remember the sound of the doors locking. I wasted 4 hours to get the car unlocked by BMW, so never again. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #22135 14th Jan 2010 9:34pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Mine has locked itself a few times when I've been stood outside. It's never done it when I've had the keys in it, but like James I always wind the window down when the keys are in it just in case as I don't quite trust it. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #22136 14th Jan 2010 10:11pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Yes, that exact issue. if any of the doors are open (without the drivers also being open) for more than about 3mins, the car locks and the alarm goes off. Bad times. 110 Tdci Double Cab
Post #22137 14th Jan 2010 10:26pm
Eduardo
Open a window is a good option but, we never leave the key in the car for other reason...
We do as a safety measure against car thiefts
Unfortunately, here in Chile is quite common that some thiefs take advantage of the people that leaves the key in the car for example to open the garage and stolen cars (I know at least 2-3 near cases).
Cheers Eduardo
Post #22138 14th Jan 2010 10:28pm
Porny
Site Sponsor
Re: Does your defender
AndrewS wrote:
lock itself.
I've slept since I did this (need to check saved settings).....
But I'm sure you just need to have the settings changed in the 10AS (alarm ECU) - I went out to tune a Puma in Athens and it kept locking itself.
On the settings page for the 10AS unit there is an option for 'Relock' - This determines if the automatic arming with central door relocking function is ENABLED or DISABLED. This needs to be changed to disabled.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #22140 14th Jan 2010 10:51pm
markus17
South Africa 2008 Defender 110 Puma 2.4 SW Tonga Green
If my key remains in the contact slot all is fine.But if it is within 30 cm of it (for example lying on the front seat) or in my pocket outside of the vehicle, the Landy locks itself within 2 or 3 minutes. I got stuck once and had to drive 50 km home in a rented vehicle to fetch my spare keys. Never again! I have got now a spare key hidden near my long range fuel tank
Post #22147 15th Jan 2010 6:44am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Yep happened to me new years day in a blizzard, luckily afriend with a land rover was nearby and went for the spares. Tried to recreate it and haven't managed so far. When I shut the door it didn't lock straight away I just heard it as I walked away. Going to have another play when I get home and see if I can make it do it. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22152 15th Jan 2010 8:16am
Grockle
no not had that happen (yet) 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #22153 15th Jan 2010 8:20am
AndrewS
How cool is this forum. So there is something going on with the self locking. Mine will lock when the key is out of the ignition. We fix water tanks in remote places so security is not always an issue. The thing is it does not do it every time I would imagine once or twice a week.
Post #22156 15th Jan 2010 9:58am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Its a setting in the Lucas10AS unit that can be configured.
http://www.blackbox-solutions.com/shop/help/SM031.html 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #22160 15th Jan 2010 10:47am
willy eckerslike
How do you configure it to do it randomly when you least expect or it's snowing Rolling with laughter
Does this mean we can interrogate it or change the settings, if you shut the door with the drivers doorlock button depressed it just unlocks itself, so not sure how it randomly locks itself. My keys where in the ignition at the time Original Member Pie n Pea Club.
110 HCPU Tipper
Post #22170 15th Jan 2010 11:41am
AndrewS
Thank for the link dm Thumbs Up
Just had a quick look through and I could not find the following options so I can disable them.
driver walking from car, quick lock it.
driver is up to has ass in mud, quick lock it.
driver walking to car with arms full of kit, quick lock it.
Post #22174 15th Jan 2010 12:05pm
dm_td5
But they all come under the one heading: Will the driver be inconvenienced if I lock it?
Or to pseudo code the situation
Loop
Has car been left unlocked? If NO then exit loop.
Are keys inside unlocked vehicle? If NO then exit loop.
Will Locking the vehicle cause maximum inconvenience to driver? If YES then lock vehicle
Repeat 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #22179 15th Jan 2010 1:02pm
