Home > Puma (Tdci) > Starting/ECU problem |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
I heard of one other person having a similar problem - but for them it would shoot to hot whilst driving and power down.
There was some talk of the fault being with the radiator and mud - with success being seen after completely removing it and cleaning it out...i dont persoanly dont know if i subscribe to it but hey Mike |
12th Jan 2010 9:41pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
it's def an ecu glitch rather than a murky rad issue 2.4 90 XS
13th Jan 2010 8:26am |
SSM42916
Models LD - Defender Title Defender non start condition 2008my onwards Last Modified 25-NOV-2009 12:44 Category Electrical Symptom 203000 Basic Electrical Content Issue: Vehicle is in a not start condition and appears to be Immobilised. Cause: Several potential causes for this symptom, Land Rover request you follow the action below. Action: Use the attached flow chart when diagnosing a non start condition. It would be appreciated if you could respond via EPQR giving details and a reference to the point in the diagnostic flow diagram the non start issue was resolved, or if a non start condition cannot be resolved, in which case it may be necessary to arrange an Engineering visit to view the vehicle. or SSM37318 (I can see it only in italian no in english on landrovertechinfo.com) Models LD - Defender Title Nessun avviamento con l'indicatore temperatura in rosso. Puma 2.4L Last Modified 11-FEB-2008 09:42 Category Sistema elettrico Symptom 203000 Sistema elettrico di base Content Disadvantage: The vehicle does not set off and l' pointer temperature is in the red zone. Some communication with the PCM could moreover not sussistere. Cause: The fuse P110 C0602 could be burnt. The fuse is located under skillful the front seat. It is prayed to consult the attached document for l' location. Participation: To control the fuse and to replace it according to necessity. Once that it has been characterized the root cause, it is prayed to send a EPQR.(ALTAVISTA TRASLATION NB!!!) C0602 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th Jan 2010 12:25pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Interesting - I can't find that last one on the GTR - what section is it in? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
13th Jan 2010 9:00pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Hi there
I detect this difference between the SSMs published in English and in other languages. In fact the one that you refers appears only in Italian language (not english, not spanish). Some time ago appeared one in Spanish and Italian but not in English. Why?, I dont know. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Jan 2010 9:20pm |
Different markets - different maps, recalls, actions, customer complaints, environments.
Just like the heated breathers for the russian zone (although some of the temperatures over the last week!) Mike |
13th Jan 2010 10:16pm |
Michael S Member Since: 12 Jan 2010 Location: In an Essex field Posts: 21 |
Oh well I should be encouraged for the Defender that this is an unusual problem, but I am a little worried that this maybe the sort of irritating problem that doesn't go away by itself and will be hard to rectify. Guess I'll have to keep driving it to the dealers yard until it spits its dummy out there.
Michael |
14th Jan 2010 8:53pm |
Spoke to dealer today who has hopefully found the root of the problem - too much silicone injected into the back of the plug that goes onto the ECU covering some of the pins causing occasional poor connection. Still seems a little odd the problem only manifests upon a restart but here's hoping.
Michael |
28th Jan 2010 10:00pm |
Wow! Not heard that one before. Lets hope they've resolved it. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
28th Jan 2010 11:42pm |
Sorry to report the problem is still occurring - I can work round it by pulling the 30 amp ECU fuse under the seat but it's not satisfactory. Dealer would like it returned by LR assist (largely so they don't have to provide me with a car!) but I'm still waiting for a convenient moment for the fault to occur and call assist. It is of course like all intermittent problems and won't demonstrate itself on demand! It's made even more inconvenient by the fact it occurs when you go to start the vehicle when I need to get somewhere.
Michael |
1st Feb 2010 8:20pm |
dullbird Member Since: 25 Aug 2007 Location: sydney Posts: 87 |
Michael can you describe your symptoms?
I had a starting issue on my defender this morning Key fobs stopped working (no batteries were not flat) turn the key the starter would crank the engine would almost fire then stop.....and the horn would sound twice.. turn the key again the starter would crank but for only half the tie and then stop turn the key again just dash lights......leave it for a minute or two and or remove the neg on the battrey for a min and start the whole process again. I had mine flat bedded to the dealer as we tried with NRMA (AA) to get the car going for 40mins...and when it got there they fired the bloody thing off and drove it off the truck they check for fault codes and nothing was wrong... YOU KNOW REHAB IS FOR QUITTERS!!!! |
15th Feb 2010 11:03am |
jammyk Member Since: 15 Feb 2010 Location: Brackley Posts: 13 |
Something similar with my 08 110 XS , every two days it has to be jump started - despite the battery being 'good'. It will be on its way back to the dealers tonight for a week ong stay to see if they can
a: replicate the problem b: fix it Annoyingly, when its been tested by LR assist, and the dealers, there is no earth leak shown. Also, when 'jump starting' the process is as follows: scenario 1: attached leads to donor, leave for 5 mins. nothing. scenario 2: Attach leads to donor, rev immediately, then start is immediate. Seems like the 'power surge' resets something... but then thats a layman describing symptoms without knowing what the fault is. Thoughts? Has this been seen elsewehere? ignorance is bliss... |
15th Feb 2010 2:52pm |
munsterlandy Member Since: 17 Dec 2009 Location: munster Posts: 52 |
hi guys. Similar to dullbird mine turns then fires then stops, horn sounds etc.
What i do is lock and unlock the vehicle 3 times and seems to clear issue. however fob never stopped working on mine. didn't try manual lock and open so not sure if any help. |
15th Feb 2010 5:07pm |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
may not be related but I has the same thing on 7 year old TD5, go to start, turned over but would no fire up, noticed tamperature zone in red but not hot, then later would start and then run rough like it was missing the main stealers said computer stuffed!!!! then I found a thread: http://forum.landrovernet.com/showthread.p...ost1171151 just by running and extra earth wire from the ECU to a different clean chasssi point it went away!!! and cleaned the other earth connection |
15th Feb 2010 7:11pm |
