Home > Maintenance & Modifications > Advice needed
spudfan
Ireland
Advice needed
Are these suitable for use with the Puma?
http://www.micksgarage.com/proddetails.asp...p;pk=11842 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #220814 20th Mar 2013 11:26pm
macduff
From my experience a 1/2" ratchet with extention will do axles and xferbox , gearbox usually has a torx head , can't recall what the sump bolt is but probably covered by a socket set. So don't see much need for that on a puma . Refer to oil drain threads for more info. 2023 110 P400e
Post #220820 21st Mar 2013 12:45am
Porny
Site Sponsor
Puma is a 13mm for the sump...
Just make sure you use a good quality six sided socket.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #220825 21st Mar 2013 7:47am
