Home > Puma (Tdci) > Intermittent TC and ABS Warning Lights!
Page 1 of 3 123>
K9F
Not overly concerned as with the snow and ice it's not too problematic to check everything is working and hunky dorey which it is!
Had a couple of occurrences whereupon i've just started driving and noticed that my TC and ABS lights have illuminated. Each time I have stopped turned off the engine and subsequently restarted rebooting everything up again with no further problems. I am not due to visit a dealer for some time but wonder whether I should place a little more priority or concern on this issue.
Question If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21921 12th Jan 2010 10:36am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
If every time you spin a wheel i.e. the traction comes in and the warning lights come on then looks like you have a faulty wheel speed sensor. Just get em to sort it next time you're at the dealers. Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21926 12th Jan 2010 11:27am
K9F
Icing Up Maybe????
Thanks Willy,
It only happens on driving after initial start up. After stopping and rebooting I can get the Traction Control and ABS to work no problems at all and there are no lights then 'latching on!' Everything seems to work 'like it says on the tin' so to speak. Could the problem possibly be down to the vehicle being left for a prolonged period and icing conditions I wonder? Once I am at work the Defender sits in it's parking slot for several days without useage sometimes. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21927 12th Jan 2010 11:36am
rangra
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Java Black
I'm sure it says in the handbook that the TC light will illuminate for 2 seconds each time it kicks in. But it shouldn't stay on for any longer than 2s as this indicates a fault. the ABS I don't know about. LAND ROVER DEFENDER 110 XS SW 2.4
Post #22002 13th Jan 2010 3:00pm
mse
The TC light as mentioned should come on to show its operating. the ABS light shouldnt unless there is a fault Mike
Post #22011 13th Jan 2010 4:19pm
Glynparry25
But TC light will come on when there is a ABS fault as it uses the ABS aystem to work.
Glyn
Post #22013 13th Jan 2010 4:28pm
K9F
Makes sense!
Makes sense Glyn,
As mentioned once electrically rebooted both the ABS and Traction Control operate perfectly with all indications as they should be. It has only happened two or three times on initial start up/moving off over the last few weeks. As we are now moving into milder weather I shall continue to monitor and take it into Land Rover straight away if the fault persists. If not, i'll wait until next service and mention it then! Thanks. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #22016 13th Jan 2010 4:44pm
discocuzzy
Mine does exactly the same mate You cannot teach stupid people to do clever things
Post #22029 13th Jan 2010 8:02pm
mse
Glyn
Yes i know that - maybe i should have been more clear; my point was that only the TC light will come on when TC is working.
Any other scenario indicates a fault Mike
Post #22048 13th Jan 2010 10:04pm
Glynparry25
Thumbs Up
Glyn
Post #22049 13th Jan 2010 10:05pm
rangra
Scrap what I said, it's supposed to stay on for at least two seconds. LAND ROVER DEFENDER 110 XS SW 2.4
Post #22132 14th Jan 2010 9:19pm
K9F
Booked In Thursday!
Since posting, my fault has got progressively worse. It happens every time now and even when it has been 'rebooted' and cleared I can drive without reoccurrence to where I'm going and as soon as I reverse the vehicle it comes on again straight away! Reckoning I've got a sensor out! Booked in thursday this week. Having the front bumper replaced under warranty as well, the underside trailing edge paint is flaking like bu993ry! Will let you know how I get on!
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #22322 18th Jan 2010 7:57am
K9F
Sorted Hopefully!
Took it into TH Whites where they swapped out the bumper under warranty. They aparently 'ran a diagnostic' on the TC ABS system and 'suspect it was a dodgy earth!!!' Reading between the lines they had a little fiddle and the fault went away. We shall see, I insisted on a provisional booking in a weeks time together with a courtesy vehicle should the fault return. Can always cancel it if it's sorted! Sorry I/they couldn't be a little more precise for 'fellow sufferers.'
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #22697 22nd Jan 2010 10:45am
K9F
Guess What?
Vehicle's back in today. 20 minutes after picking it up the fault reappeared. I had already made a booking (see previous post) and have a courtesy vehicle as well so if it's not fixed by lunchtime when I knock off they'll not see me or their courtesy vehicle til Monday at the earliest. Fault beginning to get on my t1ts a little now......
Will naturally let you know how I get on....... If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23152 29th Jan 2010 7:44am
Naks
this is starting to sound like the infamous Disco2 3 Amigos problem?
Post #23156 29th Jan 2010 7:54am
Page 1 of 3 123>
