![]() | Home > In Car Electronics > Original OEM Alpine Subwoofer - Pictures required |
DXB90 Member Since: 17 Feb 2013 Location: Dubai, United Arab Emirates Posts: 22 ![]() ![]() |
No one????
buellbeast Member Since: 28 Nov 2009 Location: RLD Land Posts: 94 ![]() ![]() ![]() |
I have one ill take some pics tomorrow although I don't think I saw any mountings inside the cubby box, unless they mount it with countersunk fittings and then trim it
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
the wires all run outside the box just the plate is located inside the box and the amp is bolted to the plate from the outside the wires i believe run under the cubby.
hope this is helpfull |
also the cubby with the sub attatched is an inch or so shorter than the standard one without, there is nothing special to how they have fitted it just drilled holes through the trim, box and interior card thats it
Thanks Rich
![]() Last edited by DXB90 on 17th Mar 2013 7:28pm. Edited 1 time in total |
Thanks buellbeast
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
not sure if this helps but i put an Alpine sub on the back of the cubby box.
![]() Click image to enlarge BM52 |
there is no difference in height at all just length if i have one at work ill get you some pics aswell, cant be 100% sure if we have one in
Rich, got you, where do they shorten the 'cubby hole' presume it as a different pad too? Is this in microcat?
the whole cubby box is shorter from front to back, they have taken an inch or a little bit more off the front section where the slope is, its at a steeper angle now, i have got one of each i can take pics of to show you ill post them tomorrow.
the plate for the inside has 4 threaded bars that will show through the back of the cubby that the sub will fix to, i can get some measurements for the holes when i take the pics. |
there must be a new part number its not just chopped, the new microcat disc has arrived so ill take a look at it and see if there is a part no for the new box for you also
Cheers rich
send me your email by pm DXB90 and ill send all these pics and hole positions for you.
and yes there is a part no for the new cubby but not sure if it comes with the sub it is in the description and it cost £215 to us if i remembered the price correctly obviously plus vat |
