Home > Maintenance & Modifications > Rear door replacement? 110 SW
Hans
France 2008 Defender 110 Puma 2.4 SW Keswick Green
Some time ago I drove my 110 SW backwards against a pole. The rear door got bent and the spare wheel is now making it difficult to access the door handle. My dealer told me that the aluminium door cannot be pushed back into its original shape and needs to be replaced.
Is this true? Any suggestions? Hans
http://www.orlaya.fr
Post #21969 13th Jan 2010 9:17am
K9F
Aluminium Panels!
Aluminium by virtue of it's characteristics is not as malleable (flexible) as steel. Quite often aluminium is also laminated to add extra strength. It is also likely to crack when bending leaving you open to intergranular corrosion.
If as you say the dealer says it cannot be fixed and has to be swapped out you have nothing to lose taking it to an independant 'body shop' and getting a seperate 'expert' opinion. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21973 13th Jan 2010 9:57am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I thought the rear door was steel now?
Post #21974 13th Jan 2010 10:01am
Hans
Re: Aluminium Panels!
Thanks, I'll get a second opinion first. Hans
Post #21977 13th Jan 2010 10:40am
Hans
I was told it is alu. It feels like that anyway, but I'm no expert. Hans
Post #21978 13th Jan 2010 10:41am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
In doubt, try a magnet Smile I think It's still an aluminium panel on a steel frame, just like before.
Land Magazine (#84) from Dec. 09 in France has an article on how to repair aluminium panels (when possible), it doesn't look like an easy task Smile
Also maybe check on ebay for second hand doors, might be cheaper, you'll have to respray to get the right color though.
Post #21979 13th Jan 2010 11:31am
Hans
I should have thought of the magnet!
I'll try to find the 12/09 issue of Land Magazine, could be helpful, though I doubt if I'll be able to do it myself. A second hand door sounds like a good option. My Def will be in for P019 and Q068 next week, I'll ask my dealer about it. Hans
Post #21980 13th Jan 2010 12:19pm
o4dn
I just made the test, and to my great surprise, it seems all doors are now steel... The magnet applies on any place on the side or rear doors!
Duh! Anybody confirms?
Post #22021 13th Jan 2010 7:54pm
dgardel
Italy
Is your car a "Puma"? if YES the rear door IS A STELL DOOR!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #22025 13th Jan 2010 8:39pm
Hans
You guys made me curious so I checked with a magnet and it sticks to the door indeed. So it must be steel (or an alloy with enough steel or iron in it to make magnets stick). I'll try to get it repaired and let you know. Hans
Post #22030 13th Jan 2010 9:06pm
RED-DOT
The front doors and the bonnet are now steel too...LR comes out of the dark ages! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #22063 14th Jan 2010 12:31am
mse
Only to commit to going back to ali on all production cars (the right way) Mike
Post #22110 14th Jan 2010 6:11pm
AndrewS
I have had the rear door card off and there is a fook off frame. It carries the spare so its pretty robust. Having said that. Take the spare and spare carrier off, take the door off and drive over it and flatten it out. PS you may want to take the glass out. Or take it to a body shop Thumbs Up
Post #22111 14th Jan 2010 6:18pm
Hans
I could ask my wife to iron it, but it looks more like a body shop job to me. Wink Hans
Post #22116 14th Jan 2010 6:35pm
