Home > Puma (Tdci) > aircon issue |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
As far as i understand the A/C, when on cooling, cools the air coming in which causes the water vapour held by the warm air to condense out, hence the water coming from the A/C drain by the gearbox. If the air temp: is below a certain value, about 10C it is unable to function, something to do with the temp: differential between the A/C compressed refrigerant and the intake air.
During winter you will tend to be heating the air thus the heated air will have the capacity to retain more water vapour, the exact opposite to summer when you are cooling the air, thus reducing it's capacity to retain water vapour. http://www.airconcars.com/html/how_it_works.html LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
15th Mar 2013 11:31pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
diolch yn fawr Welsh Gas. That sounds logical
16th Mar 2013 8:41am |
That was my (sound) logic last year, then it turned out to be the foam seal
Hostage tape over the foam seal for a few days (ugly but effective) proved rain was being driven upwards through the seal at motorway speeds. Probably aircon though Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Mar 2013 9:47am |
Check the rubber water drain draining. could be clogged.
Not confu to check, see the pic...... Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
16th Mar 2013 12:25pm |
