![]() | Home > Puma (Tdci) > Brake pad wear |
stevie Member Since: 16 Sep 2008 Location: Nottinghamshire Posts: 246 ![]() ![]() |
Forgot to mention one good point, I ve got a nice range rover autobiography 4.4tdv8 to drive whilst they look into the issue
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
ouch. Mine is on 21k on the original pads and even wear. but i will check them again just to be sure BM52
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
AFAIK mines just turned 30k and on the original set. They do need changing ASAP now tough which I will do. Reason I can't guarantee they are 30k is because I'm the second owner from 13k. But I would be they are original from the factory.
I'd imagine even though I'm no expert the the un-even ware is due to poor alignment with either the calliper or the disk or maybe both. It'd also compromise braking performance too I'd imagine,. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
I was just wondering about the high milers out there who also tow alot like noworries4x4. It would be interesting to hear about their brake pad wear rates BM52
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I replace mine every 12 month average 16 k a year the rears wear more than the front as its loaded all the time
![]() And there are a lot of hills round me and my work Last edited by mick on 14th Mar 2013 10:30pm. Edited 1 time in total |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
34000 miles ( 54400 km ) Original set. Plenty of pad left all round.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php Last edited by WelshGas on 14th Mar 2013 10:18pm. Edited 1 time in total |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
2008 110 station wagon, 78,500 kms and still on the origional pads.Last service indicated that the front pads were 50% worn while the rears were 30% worn. 1982 88" 2.25 diesel
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 ![]() ![]() ![]() |
It makes me giggle...whilst mostly used off road and most of that is on a sandy site, my pads have to be replaced 3-4 times a year, that'll be once every thousand miles or so then! The joys of having a Defender solely as a toy!
Andy. |
Do you ever use the brakes? ![]() Andy. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Uneven wear across a caliper suggests sticking pistons in the less-worn side.
Used mainly by the wife. That makes the brake pad longevity even more impressive. ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Original pads on 63000km but needs to be changed now.
Well pick it back up today and the dealer seems to think its within tolerance and so do land rover. According to land rover service specs, if it does a lot of sandy off road work then an inspection is due every 3k. Can't be arsed to keep banging my head against a brick wall and asking why the pads have lasted for less than half the distance than they did when the vehicle was new, even though the driving and work load of the vehicle has not changed.
The dealer has replaced the breakers FOC and we have agreed to inspect the brakes in 3k and assess the situation then. So I'll update in about 2months. |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
I am assuming the discs are not being changed? As discs wear the will chew pads more.But 6k does seem a little quick.As for the uneven wear this would point to a caliper problem.
My 90 did 60k on fronts and 70 on rears and then only changed them because I had the wheels off. Its never over in my land rover. 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
