Home > Maintenance & Modifications > BAS Remap Interface Forum Discount Offer
Will you be intrested in this product
Yes
100%
 100%  [29]
No
0%
 0%  [0]
Total Votes: 29
Page 2 of 4 <1234>
bell-auto-services
Nice picture m8 , im glad was all ok and the tool helped read/clear other pumas faults.
Send me some pics of the rip when you get time id be intrested possiibly for next year.
Regards Pete
Post #4398 1st Nov 2008 8:36am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Andrew,
What is the half tune you have on yours?
One the way down what was your average mpg?
Also I don't know what temps you were in but did you notice your transmission running hot while cruising? Something I had with mine while returning from te Alps this year, popped a few oil seals.
Boy
Post #4399 1st Nov 2008 9:45am
bell-auto-services
Andrews half tune is exactly that, he wanted a map that was weaker than the norm incase he was stuck in the sand and had to give it full bore for long periods of time.
Regards Pete
Post #4400 1st Nov 2008 9:48am
The Boy
Thats clever! I didn't know you could do that.
Mine is back at the dealers again as it gave up the ghost on th eway home. I still think it is the PCJ issue as it only has done it when cold and for the last five times it had to be recovered they told me it was water in the fuel but how many times can you do amod to the breather pipe before you start looking somewhere else?
Post #4401 1st Nov 2008 9:58am
bell-auto-services
Good luck with it, its a shame they cant get to the bottom of its mysterious problem.
Let us know if and what they find.
Regards Pete
Post #4402 1st Nov 2008 10:01am
The Boy
I am hoping they will sort it this time! As the land rover assist chap draind some diesel from the pump and though there was a little water not enough to (in his words) to have any effect. Out of interest it was a fuel code that came up P1169.
Post #4403 1st Nov 2008 10:11am
AndrewS
The Boy wrote:
Andrew,
Boy
MPG to be honest I have not done the exact sums but I reckon about 24 ish. Last year without the re map we were getting 16 -18 Big Cry Considering we were loaded and had loads on the rack 24 is good.
We had no issues at all with the car. I must admit I have a bit more faith in the vehicle now. You should have seen the places we drove in very very soft sand.
Post #4412 1st Nov 2008 1:00pm
bell-auto-services
There is a new software and firmware update available for my BAS interfaces, you dont need to have is if your BAS remap interface is already up and running but if we need to make changes or map update in the future you will have to use this new version software instead.
Most of you will have version 3.47 some 3.66 the new version is 3.72, it can be downloaded from the link in my signature.
Pete
PS The units are still on sale at the original offer price and are in stock pre programed with the new firmware.
Post #21887 11th Jan 2010 7:32pm
The Boy
Thanks for the update Pete, mine is going in on Monday to reload the new update. If the dealers get it to work properly this time I'll drop you a line.
Post #21891 11th Jan 2010 7:55pm
bell-auto-services
I thought your update was on and ok now ?
Pete
Post #21892 11th Jan 2010 7:57pm
ian964
Hi Pete,
If the interfaces and map are still available at the offer price, I would like one please - ian dot reynolds at icap dot com
BTW, if I have two vehicles, do I ned to buy two interfaces, or can I use one interface for both (have a D3 and a Defender TDCi on the way)?
Thanks
Ian
Post #21901 11th Jan 2010 9:24pm
bell-auto-services
Hi Ian, email sent.
The interface can only work on one car at a time so you would need 2 interfaces, i can offer you a small discount if you order 2 at the same time.
Pete
Post #21902 11th Jan 2010 9:45pm
ian964
Thanks Pete, mail received.
Ian
Post #21904 11th Jan 2010 9:54pm
bell-auto-services
dtc id="P1169"> Fuel rail pressure sensor in range but high which i think the update is designed to cure.
Pete
Post #21907 11th Jan 2010 10:37pm
The Boy
Pete
Yeah sorry, I meant that if they (the dealers) redo the download I may need to contact you to give me access with the BAS box.
Post #21931 12th Jan 2010 1:01pm
Page 2 of 4 <1234>
