Home > Tdi > Bonnet mounted windscreen washers.
Page 2 of 2 <12
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Hi Steve,
I've not been able to find the link for the heated washer from a 3 series, i don't suppose you have the link available do you?
Its something that i'd like to do on the 200Tdi and also possibly on the Puma as well if it works well. I'll try and plumb it in temporarily on the Tdi to see if it will work first from various positions and then if its viable i'll make it more permanent.
Regards,
Mark
Post #217415 9th Mar 2013 11:50am
ZeDefender
I have HeatShot installed, as well as the P405 wiper arm washers. The setup clears everything from the screen and puts the washer fluid exactly where it needs to be, using less of it, especially in Winter.
I know mine looks a bit "Heath Robinson" (of whom I an avid fan, as well as Tom Lehrer and Gerard Hoffnung), but so is the whole vehicle. The advantage is that in an emergency I can just pull it off at the front and clip the original nozzles back on.
Oh, and I took it through the car wash yesterday (terrifying experience) and everything remained intact Thumbs Up Tell someone you love them today because life is short.
Post #217420 9th Mar 2013 12:10pm
roamingman
Years ago when I started driving never had washers on car Austin A45 van or lorry Ford Thames Trader, use to cut Apple or potato in half and rub on screen water used to run off.
Showing my age know. Live Life Ti'l You Die
Teddys are out thier
http://teddybearspicnic.webs.com
http://130sasha.co.uk/
Post #217423 9th Mar 2013 1:02pm
hi Mark
here's a link to the pdf
so my plan was to use the temperature activated switch powered by an ignition feed (VSR off the aux battery that runs the breather heater)
cheers
steve
http://www.e30zone.net/e30zonewiki/images/...r_jets.PDF
Post #217424 9th Mar 2013 1:21pm
ZeDefender
Aha! One of my worse "windscreen" experiences is when I broke the wiper on my A2 at the airport (didn't bother to clear snow first Rolling Eyes ). Drove 80 km back along the motorway with sleet and slush from lorries etc. and somehow it stayed clear enough to drive...just. The wiper is still dodgy, so I will keep a few spuds in the boot, just in case Thumbs Up
Off Topic sorry Embarassed Tell someone you love them today because life is short.
Post #217434 9th Mar 2013 2:08pm
Page 2 of 2 <12
