Home > In Car Electronics > Single din radio unit with seperate screen
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
I was wondering if anyone ever seen a single din unit with a seperate screen.
What I exactly mean is this: you have these single din units with the pop-out screen but they obstruct the dash buttons behind. Are there no single din units with a seperate screen?
If so I would just create a flip holder on the roof, maybe on a ball (like the outside mirror units) so I can even turn it facing me.
Another solution as to have a full unit somewhere in the car that can be controled by seperate touch screen and have no unit in the single din slot at all (make it into a cubby box or something) and again put the add-on screen on the roof.
I've also seen these double din facias but I've heard some reservations concerning the viewing angle.
Post #217124 8th Mar 2013 12:40pm
Perhaps easier to relocate or duplicate the switches ?
I've put the two switches I use most to the outside positions and duplicated the Hazard switch into the centre cubby box console
Post #217126 8th Mar 2013 12:42pm
ibexman
Must be easier to connect a dvd screen ??? or get a single din with dvd aux Thumbs Up
Post #217127 8th Mar 2013 12:46pm
Nearly all DVD single DIN HU's have video and audio out to connect to Aux items such as screens many are splitt-able even so for example DVD HU in dash with monitor open or closed either way playing a DVD or other Video source but say you could have two TFT screens on the rear of headrests or a larger on on the roof or indeed the lot is probably possible. Pure pointless extravagance IMO to go quite that far really IMO but perfectly possible and does look good once done. Very attractive to steal though also. Rolling Eyes Rolling Eyes $W33T $0U7H3RN $UG4R
Post #217134 8th Mar 2013 1:07pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
As Steve suggests, maybe add an extra screen.
Get one with a flip out screen and connect extra screen (quite cheap) then you have the choice of which one to look at.
The flip outs only really impact the hazard lights switch and rear screen wipe/heated screen so not a major issue. Most work quite happily with the screen shut for usual radio/cd/ipod music, you'll only need the screen for satnav/dvd/prettiness
Could be a good move, you could then have say satnav on one and reverse camera on the other (or any combination) as long as the headunit allows you to select output to rear/auxilary screen.
Thumbs Up 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #217143 8th Mar 2013 1:23pm
zone30
Maybe a single din with pop-out screen for sat nav would just do. Never thought you only need to pop it out for satnav.
I have a dual din my other car and never really use the buttons on it but touch the screen. Was thinking the same is true for pop-out systems.
Concerning theft the proposed setup would enable me to flip it away from view so the main unit wouldn't look so high tech (last proposal doesn't even have a unit in view).
Concerning rear view cams I m thinking of a seperate stand alone always on setup (see mod roofbox in tdci section).
Basically I really only need radio - usb - phone-connection - satnav to work over the speakers. Have the ability to watch movies on my other system but rarely do, so that's not really necessary. A 7" screen is quite ergonomic to use though.
Post #217150 8th Mar 2013 1:47pm
Couple of choice's I'd recommend either what DJ has (Hopefully he'll tell you the model) Or the new version of mine. The Kenwood KVT-526.
This is my KVT-729 pictured below.
Post #217197 8th Mar 2013 5:39pm
JWL
Don't you find you burn your arm on that gas ring on your cubby box Whistle
Post #217222 8th Mar 2013 6:47pm
No, Gives your elbow a thump instead though. Mr. Green $W33T $0U7H3RN $UG4R
Post #217227 8th Mar 2013 6:55pm
mikeh501
do they do one of these where the screen comes out and goes down instead of up? im thinking of getting one of those new mud roof consoles and so obviously it would need to tilt down otherwise it would hit the roof!
Post #217299 8th Mar 2013 9:34pm
I highly doubt you can. If you wanted that kind of set up how about a larger screen that flips down?? A roof mounted one rather than a HU. $W33T $0U7H3RN $UG4R
Post #217301 8th Mar 2013 9:36pm
zone30
Post #217314 8th Mar 2013 10:21pm
d j hutton
I saw a couple where the screen was below when I was looking for mine, but I think they were angled up towards the driver. Not a known brand though..
Dj 1989 200tdi 90 csw
Buy British 🇬🇧
Post #217327 8th Mar 2013 10:52pm
Probably made of Chinese rice paper then if not a known brand. Neutral
It'll also be quite low so not very good to look at similar to the double DIN issues of the screen angle being not very good compared with the drivers positioning. $W33T $0U7H3RN $UG4R
Post #217330 8th Mar 2013 10:56pm
zone30
zone30 wrote:
Investigating this setup http://www.defender2.net/forum/topic1090-15.html
Screen and radio unit not related but it does show te idea. Only I would put the screen on the roof in a flip box so you can flip it out of sight.
Post #217666 10th Mar 2013 9:04am
