Home > Puma (Tdci) > Wrong spec |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Have a look mate and check. I wouldn't have thought that the wheels influence anything else though |
7th Mar 2013 10:27pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
I'd check the adjuster bolts for the steering lock.... ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
7th Mar 2013 11:09pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
It used to be that the anti roll bars came with the boost wheels
8th Mar 2013 12:46am |
stevie Member Since: 16 Sep 2008 Location: Nottinghamshire Posts: 246 |
An xs would come with anti roll bars as standard. A county or below on the standard steels could come without anti roll bars but if you spec the lower model with heavy duty rims then it comes with anti roll bars. Well they have done on all the ones I've ever ordered in various specs . Yours should be fine.
8th Mar 2013 7:50am |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Look at the folders, you'll notice there's a difference between steel and alloys. I think they have different shocks, but not 100% sure
8th Mar 2013 8:55am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
You should have kept (bought) the steelies as well... ideal "off road" set then
8th Mar 2013 9:32am |
Hmmm Defender specs are notoriously unreliable, best way to check is to get underneath and have a look!
8th Mar 2013 10:00am |
Mackers-a Member Since: 16 Dec 2012 Location: Torquay Posts: 24 |
Anyone able to post a picture of them on a Puma 90 please? As mine does not seem to have them, however I may be being a little stupid.
8th Mar 2013 5:33pm |
Google may be your friend Basiscally a big "U" shaped tubular section that faces forward behind the rear axle An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
8th Mar 2013 5:58pm |
Tried google and got an idea of what the aftermarket ones look like but nothing for Puma. Cant seem to see them on my truck. Ahh well better get it on a ramp at the stealers bummer
8th Mar 2013 6:08pm |
Not sure if they are different on a 110, but think this is what you are looking for, but on a 110...
Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
8th Mar 2013 7:57pm |
Thanks I thought as much I saw empty brackets underneath mine.
8th Mar 2013 11:18pm |
Right confirmed. No anti roll bars in place, rather miffed. Hopefully a simple fix. Only problem is now living 250 miles away from the supplying dealer .
10th Mar 2013 7:50pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
you been tucked up like a kipper!
get on the phone and reject the car...not an xs...not worth the money |
10th Mar 2013 7:52pm |
