Home > Puma (Tdci) > Diesel smell in cab its so bad it get in your mouth
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
as my land rover DC is waiting complete respray by my dealer i have had to keep it a little longer Big Cry 3 years
its been very good in the snow but filled it up the other day with diesel. and when warm the fumes have been so bad we have been driving around with the window open any idears before i take it back
was very impressed with tc in the ice its been top dog made it home most days with the bad weather
so would like to get it sorted on the quite so my boss let me have a new xs Mr. Green
and it got to work over the companys L200 and showgun Rolling with laughter
daniel
Post #21627 8th Jan 2010 8:07pm
RED-DOT
Have you looked at the Fuel Pressure regulator located at the rear drivers side corner of the engine, beneath the inlet manifold?? A common fault on TD5's and i have just done my Discovery which takes 2-3 hours but 1 hour i believe on a Defender.... £100 ish from Land Rover.
My old one was dripping and i have it for sale with it needing an O ring to fix and it comes with the two pipes as supplied from LR. (£60)?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #21671 9th Jan 2010 9:41am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Agreed,
I have had a similar problem with my TD5 and it turned out to be the pipe that comes from the FPR to the block. Stick you head upder the bonnet and use your nose! 2002 Defender 110 DC
Post #21673 9th Jan 2010 10:02am
RED-DOT
99% of leaks from FPR's are the O ring in the diaphragm which is held in place by a circlip. LR supply the two pipes that you never usually need.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #21683 9th Jan 2010 1:15pm
ben_j85jty
Mine had just had the a new FPR fitted, bt after a long run down to Cornwall the feed pipe from the FPR came loose, dumping 1/2 tank of diesel in 30 miles. 2002 Defender 110 DC
Post #21690 9th Jan 2010 2:05pm
RED-DOT
Yip, it is a push fit with a sliding plastic retainer.... not fitted correctly.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #21704 9th Jan 2010 5:43pm
Daniel TD5
thanks
its had two new fuel pressure regulators and they last about a day after fitting them then when checked it brings a the fault code back up over pressure
must have blown the seal by now Big Cry
its been left with the fault as i would not let them have it due to the weather
Daniel
Post #21806 10th Jan 2010 9:31pm
RED-DOT
Absolute Censored .. they last at least 40k miles so don't come on here looking for help and say they last for a few days then say you don't know where your leak is... wind up Poster? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #21812 10th Jan 2010 10:16pm
Daniel TD5
hi Red-DOT
Why would it be Censored yes i don't know where the leak is i have looked under the pressure rail and it has a smell of diesel so it may be that
i have had two regulator fitted first one failed at 25k started running poorly so they changed it.
that one lasted two days and went funny with poor running again and the same fault code. i am sure some one has had more than four fitted that why land rover changed the part from the complete rail to just the end valve
they are going to replace this one next time it is back in the dealers
i will come looking for help where i want. being one of the first TDCi defenders made i have had lots of problems and have found the forum a god send. i have posted lots of information as well.
i thanks you for your help but not your comments about wind up poster
Daniel
Post #21824 11th Jan 2010 8:40am
