![]() | Home > Group Buys > 3rd run group buy for the integrated remote key |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
It was on the first run thread. But that's gone.
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
It should be the same procedure as shown on here;
http://www.remotekey.co.uk/cars/land-rover/defender/ Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 ![]() ![]() ![]() |
DGardel thank you for the hard work
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 ![]() ![]() ![]() |
Daniele,
Key and Pod arrived today. Thank You! Great job. Cheers Det Here is the instruction: Instructions for the Programming Pod: NOTE: You do not need to turn the Ignition on. 1. Push the Pod into the OBD socket. 2. the blue led goes on 3. wait until the blue LED goes out, and that is it!!! The remote key now work. Once the pod is used, it will be locked. locker bleiben |
![]() ![]() ![]() ![]() IID Pro MV License |
![]() First couple of times it didn't deactivate the immobiliser. I tested it by using the old key, holding the new key near the key. After a few attempts, all good! Off to the key cutters tomorrow! ![]() Once again, thanks to our Italian supplier!.........oh and beat the English on Sunday at Rugby! ![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Thanks Daniele
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Another thumbs up from me! Thanks for all your hard work making this happen!
Does the key need to be in the ignition? |
No, just in close proximitary to the programmer. Craig Rogers
Thanks. Thought I'd better ask.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 777 ![]() ![]() ![]() |
My key arrived in the post this morning.
Thanks for your effort in doing this ![]() ![]() |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 ![]() ![]() ![]() |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Key arrived with Pod, woop woop. Many thanks Dgardel. ===================================
Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
