Home > Maintenance & Modifications > Winches
Page 2 of 2 <12
jst
so about the same as a TDS from Goodwinch with a bumper then, but also with their expertise and backup thrown in.
The point i was making with respect to challenges is if it lasts in that environment then surely its ideal for the occasional use. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #21385 6th Jan 2010 11:10am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Absolutely agree Thumbs Up I was thinking more about the real expensive stuff Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21393 6th Jan 2010 12:24pm
mse
I seem to use my winch even less than before i had one Big Cry
Ill admit to being a warn man and proud Mike
Post #21416 6th Jan 2010 5:38pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
All this talk of winches makes we want one. I bought a Tifor hand winch on the basis that I'll maybe need to use it once a year and didn't want tens of kg sitting over the front bumper for the rest of the time. Also around �150 instead of �500+.
However, the thing also weighs a ton and although I can sling it in the back I'm starting to doubt my decision. I'll still only need it once a year but I'm feeling left out Big Cry One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #21560 8th Jan 2010 9:32am
willy eckerslike
Funnily, I've only got stuck since I fitted a winch Rolling with laughter Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21561 8th Jan 2010 9:36am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Have you needed to use the Tirfor yet Alan, if so how well did it work? Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #21591 8th Jan 2010 2:06pm
bob neville
TJ101 wrote:
As for the winch
By far the best value is the TDS for David Bowyer @ Goodwinch http://www.dborc.co.uk/goodwinch/
Well impressed
Just been quoted �749 + VAT for a Goldfish 9-5c with Dyneema Bowrope, Defender fitting kit and Aircon bumper.
Does that sound reasonable or should I push Dave harder ?
Bob
Post #21616 8th Jan 2010 5:24pm
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
PM sent Bob.
I just ordered a very similar package but I managed to get in before the vat inclusive offer ended.
Post #21618 8th Jan 2010 5:36pm
bob neville
Thanks Phil.
I will be very interested to see some pictures when you have it fitted and also any 'gotchas' you find when fitting everything !
Bob
Post #21619 8th Jan 2010 5:40pm
Glynparry25
You guys not willing to go second hand? The reason why I mention it is because you could get a whole lot more for your money. Over the past few years I have purchased the following:
Superwinch Husky (Probably the most reliable winch out there) which just the casing, gears and drum was origional, the motor/ solenoids had been new and mounted it to a new Mantec bumper �550 (RRP �1400).
Warn 8275 with scorpion racing tubular bumper. The winch and bumper was like new �800 (RRP �2,000).
^^ Both of the above have been tried and tested by Camel Trophy. The Superwinch by Lone wolf transglobal expedition and the Warn is the wepon of choice by every competition vehicle out there.
Glyn
Post #21623 8th Jan 2010 6:45pm
bob neville
Glyn
I have been looking at second hand but not found anything yet that is significantly cheaper than new.
Bob
Post #21625 8th Jan 2010 6:55pm
alantd
Used it once - to pull a tree out.
It's very flexible in that you're not constrained to pulling at a certain angle, from a certain point on the car. However, it is a bit of a fiddle to set everything up and is INCREDIBLY slow. Once everything is taught, you can get into a rhythm and it all moves quite steadily but when you're trying to take up the slack then it's a bit of an ar*e - especially for 1 person to manhandle.
Good to know I've got something to rely on but certainly not as convenient as an electric winch. I've also got full cage (windows and cargo barrier) in the back and I wouldn't want all those heavy things kicking about in there if there was any chance I'd roll. One that started out as a 2.4 TDCi 110 XS
Post #22073 14th Jan 2010 10:11am
jst
if you go the second hand route just be prepared to keep spending is my experience. i have a second hand husky for �400 or so at the time. In the end it needed a refurb and new motor which cost another �300 ish. could of almost had a new one for that.
With the Goldfish range now you can have a new winch for 2nd hand money almost.
i have an 8274 front (new) and the husky as above rear and am looking to get a lowine winch for the training vehicle. at the moment TDS is the choice from my perspective for robustness, backup, price, pulling umph and low battery draw (i will only run one battery on this truck) Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #22075 14th Jan 2010 10:17am
TJ101
Second hand route ?? maybe Whistle
http://www.defender2.net/forum/post22133.html#22133 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #22134 14th Jan 2010 9:26pm
Page 2 of 2 <12
