Home > In Car Electronics > Puma towing electrics
ericvv
Have seen in the shop section here that we can buy a towing electrics adaptor to easily connect a C-tek charger to recharge the battery. Sounds a nice useful bit of kit, but my question is if the 7 pin towing electrics are always powered, so also when the car is off and locked? If that is not the case, won't be of much help of course. Below is the link to the item.
Tks, Eric
http://www.disco3.co.uk/shop/index.php?act...oductId=45 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #215689 3rd Mar 2013 8:30am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Remember this is a 7 pin 12S plug and not the standard 12N connector. The 12S is the caravan plug.
I am looking to upgrade to 13 pin which would make sense in Europe anyway.
Post #215691 3rd Mar 2013 8:57am
ericvv
Confused, and I must admit don't know the difference between an 7 pin 12N and 7 pin 12S socket. What comes as standard socket on a Puma? I know I have a standard 7 pin, which can be used for a trailer, but that's as far as my knowledge goes.
The website reads as follows though:
Quote
This is an adapter to enable you to connect a CTEK charger (12V, up to 15A rating) to the towing electrics. This allows you to charge a vehicle (Discovery 3, Discovery 4, Range Rover Sport, Range Rover, Freelander 2, Defender, Range Rover Evoque) through the towing socket. Fitted with a 15A fuse to protect the vehicle's wiring.
Both 12S 7 pin and 13 pin plugs are available, using quality plugs and genuine CTEK sockets....
Unquote
So it says that this adaptor allows to charge also a Defender....
Am I wrong in believing that the offered adaptor, i.e. the 12S 7 pin plug, would fit onto the standard Defender towing electrics socket?
And if it fits, would it possibly be a different wiring setup, so that the C-tek would not properly charge the battery via my standard socket?
Tks for clarifying, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #215692 3rd Mar 2013 9:08am
bob neville
Eric
have a look at this site, shows the difference in wiring for 12S and 12N.
The 12S is as stated above an extra socket in addition to the 12N.
http://www.westerntowing.co.uk/acatalog/Tr...agram.html
2013 Defender 90 CSW - sold
Post #215721 3rd Mar 2013 11:05am
ericvv
Bob, thanks for the link. Learned something again.
So the #3 earth is the same in both cases, but the #4 positive direct from battery exists only with the 12S, and does not exist at all with my 12N. So a no go regretfully. Pity, looked too easy.
Post #215733 3rd Mar 2013 12:09pm
me@td5.org
Eric, you can add a 12S socket. It just plugs in I think. It's a dealer part LR005921.
This would be in addition to the 12N socket that is fitted with the tow pack.
Post #215749 3rd Mar 2013 1:44pm
ericvv
Thanks for the tip, will check with my dealers. Have seen a few Defender pictures with one socket at each side of the tow bar, guess the second one must be this 12S socket. If it is really easy to plug in, might get it.
Post #215765 3rd Mar 2013 2:11pm
Phil_C
2010 Defender 90 Puma 2.4 HT Galway Green
Really useful link - cheers - was just about to start cutting holes and so on to be able to wire my CTEK in, but this will work fine on both my LR's as they both have twin electrics. Thanks P
Post #225637 8th Apr 2013 10:59pm
ericvv
Just yesterday happened to order from my LR dealer the original LR 12S socket and wiring. Same time orderered from the website shop here the Ctek 7-pin connector. When all is installed will post some pictures. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #225649 9th Apr 2013 4:20am
12S wiring is a little move involved than just plug in but not too hard Thumbs Up
Post #225651 9th Apr 2013 4:47am
JSG
Great idea - I have the 13 pin wiring on my 110 so it would be a simple plug in Thumbs Up John
2011 Tdci 110 CSW XS
Post #225741 9th Apr 2013 9:59am
mobilecentre
On Td5 the "purple" accessory socket wire is not connected within the plug on the end of the loom for the tow bar socket so has to be connected separately to enable 12S or 13 Pin function.
On Puma the purple wire is contained within the vehicle tow bar loom connector so if you buy the genuine LR 13 pin electrics kit you can plug straight in and have reverse function within the 13 pin electrics and permanent power via the purple cable.
The purple wire is normally fed via fuse 2 on the battery box fuse box under the seat.
The ignition/ fridge supply functions of the 13 pin will require additional wiring to work but if you are just looking at a method of charging that is neat this will achieve it.
If you have 12N electrics fitted (7 pin) and they are genuine LR they should just unplug and you can then connect 13 pin
Post #240421 2nd Jun 2013 10:13am
ericvv
Post #240425 2nd Jun 2013 10:47am
Mr Didot
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Baltic Blue
Eric,
How did the dealership add the second socket? - is there an adapter that allows the vehicle tow bar loom to double up?
Thanks Smile
Post #277487 28th Oct 2013 12:34pm
jst
Hi there, Please could you help when you say Fuse two from which Side? closest to centre of vehicle being no 1 or closest to outside of vehicle being no 1 Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #453937 10th Sep 2015 1:56pm
