Home > Puma (Tdci) > Just a thought: Can I install an ABS-TC in a 08 MY Defender?
Eduardo
Just that, and to do not hijack the previous post.
It is possible to install as a kit the ABS-TC package in a 08 MY without it?
Some idea about the cost?
Cheers! Eduardo
Post #21525 7th Jan 2010 9:25pm
roel
I think it is possible but you need at least other axles or just the speeds sensor parts and ECU's and some new cables. You might have to tell the software that you installed it and I don't think a LR dealer will help you with that part.
It might be cheaper to buy one with ABS and TC. Roel
2003 90 Td5 (2009-now)
Post #21530 7th Jan 2010 10:08pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
It's only electrical, no need for new axles Shocked Shocked
Going with the defender normally, the wiring is also probably already there Laughing 110 Tdci Double Cab
Post #21534 7th Jan 2010 10:30pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I seem to recall someone investigating this before and it was prohibitively expensive. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #21537 7th Jan 2010 10:38pm
roel
I don't think you will have wheel speed sensors on a none ABS vehicle. At least you don't have that on a none ABS TD5. Roel
Post #21620 8th Jan 2010 6:24pm
MK
just the modulator costs over 2000 quid Puma 110" SW
Post #21653 8th Jan 2010 11:32pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Just make silly noises, stamp on and off the brake and install a flashing led light, it's much cheaper and has the same effect. Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21662 9th Jan 2010 8:28am
mse
Not really the same effect! and you cant beat ABS/TC and you cant manually simulate it to the same efficiency or effectiveness. Whistle
You will need from memory:
Sensors
Wiring
ABS/TC ECU
Different Hubs
Different Brake disc's (maybe also callipers and pads i cant remember)
Modulator
Pipes Mike
Post #21666 9th Jan 2010 9:07am
willy eckerslike
Thud Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21668 9th Jan 2010 9:13am
ay4alex
Sensors
Wiring
ABS/TC ECU
Different Hubs
Modulator
Pipes
Oh Whistle Thud 110 Tdci Double Cab
Post #21670 9th Jan 2010 9:30am
Grockle
Ed,it would prob cost less to swop your truck for a new one with ABS/TC. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #21676 9th Jan 2010 12:00pm
dgardel
Italy
Why ABS?????
a real offroader work better WITHOUT!!!!!
Try the abs when descent a snowy hill.....................and pray.............. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21678 9th Jan 2010 12:41pm
mse
dgardel wrote:
Why ABS?????
Ignoring the fact that Hill descent is based on ABS and off road advice in the handbook says the onlly abs equipped vehicles are recommended to brake on decent
Before anyone says i know pic the speed avoid breaking is the best way. Mike
Post #21679 9th Jan 2010 12:44pm
dgardel
Italy
mse wrote:
dgardel wrote:
Why ABS?????
Sorry, I prefer lsd diff not the brake
if someoune want Hll descent, ABS, DSTC .... please chose a X5 or a Q5
have you never drove in a very icy steep reduction with abs....
TC is the best way to destroy shaft and diff Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21696 9th Jan 2010 3:43pm
willy eckerslike
The best would be to have both options i.e. be able to choose when you want traction control, hill descent etc. Then turn them off when you don't. The Hill descent works great in our freelander 1 which doesn't have a low range box, can't stop but at least you can steer :rolllaugh hill descent was also usefull on the corpulent D3.
and you can't deny that traction control on the D3 is very good. Thumbs Up If you haven't fitted a locker or LSD then I suppose ABS Traction etc will be useful on occasions, just a shame we can't decide for ourselves when we want to use it.
110 HCPU Tipper
Post #21698 9th Jan 2010 3:51pm
