Home > Maintenance & Modifications > Outside temperature gauge
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Can anyone recommend a good 'outside air temp'' gauge? Some on fleabay but from China.....and too cheap to trust?
Post #214893 27th Feb 2013 10:17pm
Watching with interest. It's one of those 'gadgets'. Yet I always check it in the Audi and often wander when I'm in the 90.
Good post chipmunk Thumbs Up
Post #214897 27th Feb 2013 10:22pm
iPints
United States 1994 Defender 90 300 Tdi CSW Epsom Green
http://www.egauges.com/vdo_mult3.asp?Type=...mp;Units=M
Not sure about quality......but it's VDO so should be good.
Post #214899 27th Feb 2013 10:26pm
Take a look at the Mobile Centre website
I've fitted one of their digital temperature read outs to the FCX 130, pictures on my 130 thread
Post #214904 27th Feb 2013 10:39pm
Generaldej
United Kingdom 2009 Defender 110 Puma 2.4 CSW Alpine White
Got one of these from China http://www.ebay.co.uk/itm/120995824095?var...1497.l2649
Mine arrived in less than a week. I'm very very happy with it Very Happy I have wired it into the radio power supply and fed the sensor end (on a 3m cable) through a grommet in the bulkhead and out of the engine bay. Will add some images tomorrow if interested.
Post #214907 27th Feb 2013 10:42pm
chipmunk
Thank you all. Will research some. Cheers.
Post #214915 27th Feb 2013 11:30pm
x-isle
Problem I've always had with the add-on sensors in any car I've tried them is not the quality of the gauge, it's not difficult to make a temp probe, but it's where to put it to be accurate.
Temp drops when driving and rises when stopped.
Be interested to know where folks have placed their sensors. Manufacturers normally place them low down at the front of the car. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #214929 28th Feb 2013 6:46am
OBDCII readers use the vehicles temperature sensor, a nanocom would work fine on a td5
Post #214930 28th Feb 2013 7:05am
Kraut
Germany 2010 Defender 110 Puma 2.4 SW Santorini Black
iPints wrote:
http://www.egauges.com/vdo_mult3.asp?Type=Outside_Temp&Series=Vision&Units=M
That's the one I got installed from the dealer instead of the oem clock, fits neat and looks better than the usual lcd-displays as it's looks as if it has allways been there
Post #214934 28th Feb 2013 7:29am
MartinK
CheckTemp2 is popular on here...I've got one, works a treat!
http://www.defender2.net/forum/topic5492.html
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #214941 28th Feb 2013 8:07am
chipmunk
Yes Craig, was hoping to pick up some probe positioning info'. Needs to be in the open but out of airflow I suppose? Wind chill factor? Very useful tool in GF's Golf. VDO one seems very expensive but looks good. Would replace clock too.
Post #214951 28th Feb 2013 8:40am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
As far as I know taking the AIT from the ECU won't give an accurate impression of the outside air temp.
Behind the bumper would be good for the sensor but if it collects snow it will give a false low.
Post #214961 28th Feb 2013 9:21am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Mine's in the headlamp enclosure, seems to work well.
Post #214965 28th Feb 2013 9:28am
MartinK
Mine's set inside the drivers-side wing, near the headlight. When the car's sitting stationary in the sun it reads a bit high, but once moving it's spot-on.
On a previous car it was located in the air intake for the engine (somewhere in the airbox) - that worked really well...as soon as the engine is started it sits in a gentle flow of fresh air Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #214976 28th Feb 2013 10:09am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
MartinK wrote:
.......I've got one, works a treat!
I too ! !
Thumbs Up
http://www.politecnica80.it/checktemp.asp?login=undefined
http://www.speedup.it/1131211/termometro-e...tecnica-80
http://nakatanenga-tours.de/shop/article_N...THERMDZ%26 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #214981 28th Feb 2013 10:41am
