![]() | Home > Technical > Coil Springs Compatibility |
dogfood1 Member Since: 10 Jan 2011 Location: Chicago Posts: 3 ![]() ![]() ![]() |
Hi there,
I purchased a set of new coil springs for my D90, described as NTO from a vendor. When I received them there were two pairs, one pair color coded "Blue/White" the other pair "Green/Yellow". From my research it seems that each corner should have a different color, and these specific color combinations aren't necessarily coils that came from a D90. This is my source: http://www.red90.ca/rovers/springinfo.html The vendor will take them back, but I have to pay to ship, which will be expensive. Do you think these color combinations will work on my V8 D90, or should I take it as a lesson and send them back and get proper coils? Thanks for the help. |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
I believe that towards the end of tdi they stopped with handed springs so two pairs of matched sounds right. Rhubarb and custard let fly with their secret weapon.
Thanks - if that's the case it's a load off my mind.
I'm re-opening this post as I'm still having trouble determining if I have the correct coils for my truck.
I compared the color codes on my coils to the published color codes around the web and have determined (unless my method of measurement is incorrect) that the specs of my coils do not match the published color code specs. Like this site: http://www.landroverclub.net/Club/HTML/Spring_rates.html I notices one set of coils has a Britpart sticker on it, I sent them an email, but who knows if I'll ever hear back. The Green/Yellow ones are about 15.5" tall, and have about 8 or 9 coils. The outer diameter is 6" and the inner is 4 3/4" (the reference guides say this color combo should be 16.2" tall and have 7.0 coils) The Blue/White ones are taller, about 16.5" tall and have 8 or 9 thinner coils. The outer diameter is 5 13/16" and the inner is also 4 3/4" (the reference guide says this color combo should be 16.44" tall and have 7.55 coils) Also, between the two pairs, there is nothing that would say "Driver or passenger" by means of differentiation. Thanks so much if anyone out there is well versed in these things. |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 566 ![]() ![]() ![]() |
I would have a word with the vendor again as if they have got a britpart sticker on them they are definitely not new take offs. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech Instagram @the110camper |
