Home > Maintenance & Modifications > Second 12V socket
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Second 12V socket
Hi all
I need to install a second 12V socket in my Puma, I already have the socket but don't know where can I take the wires to make the connection,
Is there a properly location in fuse box (for auxiliary electrics for example????)??????????
It need fuse or relay???????
thanks!!
Post #21291 5th Jan 2010 4:16pm
AndrewS
Where do you want to mount the socket ?
Post #21296 5th Jan 2010 4:40pm
Gabriel Boff
Don't know the location yet, but I'm thinkig under drivers panel, near of fuse box and pedals (remeber that is a left hand one).
But I don't worry about the location, I worry about the wire conections, I don't know from where to take the energy, and don't cause any overcharge in eletricals, understand??
Post #21312 5th Jan 2010 6:00pm
Eduardo
Gabriel,
Just from memory...
As far as I remember there is a set of cables to connect an auxiliary 12V outlet in the back, near were suppose to be the rigth side speaker.
Cheers Eduardo
Post #21317 5th Jan 2010 6:12pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
That's correct Eduardo, had mine fitted there, dealer did a thouroughly neat job.
Post #21319 5th Jan 2010 6:15pm
Gabriel Boff
Pictures of the location of the cables?????
Post #21321 5th Jan 2010 6:19pm
Remove the right rear speaker and there is a female spade socket Purple (perm live) Black (ground)
Post #21328 5th Jan 2010 7:14pm
TJ101
Correct,, and fed from the aux fuse under the righthand seat box !!
Their is meant to be another take off, in this feed, approx half way down the vehicle,, but have never found it Question Question California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #21353 5th Jan 2010 9:32pm
Eduardo
If someone knows the position of this second outlet please advice!!
Cheers Eduardo
Post #21389 6th Jan 2010 11:36am
mse
If you do a search you will find the one at the back
Just a point - that pack of wires doesnt run down the car so it would likely be outside on the chassis leg if there is such a feed or under the drivers seat Mike
Post #21417 6th Jan 2010 5:40pm
Eduardo
MSE
Pillar would be a good option to search, I didnt found nothing in the passenger seat (in our case)
Cheers! Eduardo
Post #21422 6th Jan 2010 6:11pm
mse
There is nothing behind the trim under the windows (remember mines a 90) Mike
Post #21453 6th Jan 2010 9:58pm
