Home > Maintenance & Modifications > Decat Pipe again
BruceT
South Africa
Decat Pipe again
Having received my Decat pipe i was very disappointed that it didnt have the brackets for the heat shield to be fitted to it..
What have others done to overcome this?
If I choose to just empty out the cat box instead of using this badly made decat pipe, are there any negatives I should worry about?
Thank you. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #212908 21st Feb 2013 10:39am
x-isle
Is the heat sheild required if there is no Cat?
The decat pipe won't get hot like the temperatures the Cat reaches. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #212909 21st Feb 2013 10:42am
BruceT
South Africa
I read on this forum that the heat shield has to be re fitted. If it doesn't that's a bonus. Can you (or someone) confirm please.
11MY Defender 130
Post #212910 21st Feb 2013 10:44am
Glynparry25
Thumbs Up That is spot on. The turbo and manifold will get hot but there is nothing in the vacinity for it to affect. Been running mine without heat shield for 2 years now without any issues.
Glyn Dog Sheep
Post #212911 21st Feb 2013 10:45am
BruceT
South Africa
Fantastic. thank you.
Now to decide if I want to use this one or get a copy made. The bends are all wrinkled on the inside and what looks like flux (i think its called) has not even been cleaned off of the welds. Welds look perfect though. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #212913 21st Feb 2013 10:48am
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Bruce, where did you get it from? Locally or imported?
Post #212918 21st Feb 2013 11:26am
BruceT
South Africa
Heinrich it was Imported "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #212919 21st Feb 2013 11:28am
Naks
that doesn't sound so great... --
Post #213181 22nd Feb 2013 9:48am
