Home > Maintenance & Modifications > Decat Pipe again |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 517 |
Having received my Decat pipe i was very disappointed that it didnt have the brackets for the heat shield to be fitted to it..
What have others done to overcome this? If I choose to just empty out the cat box instead of using this badly made decat pipe, are there any negatives I should worry about? Thank you. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
21st Feb 2013 10:39am |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Is the heat sheild required if there is no Cat?
The decat pipe won't get hot like the temperatures the Cat reaches. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
21st Feb 2013 10:42am |
I read on this forum that the heat shield has to be re fitted. If it doesn't that's a bonus. Can you (or someone) confirm please.
21st Feb 2013 10:44am |
Fantastic. thank you.
Now to decide if I want to use this one or get a copy made. The bends are all wrinkled on the inside and what looks like flux (i think its called) has not even been cleaned off of the welds. Welds look perfect though. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
21st Feb 2013 10:48am |
heinrichnel Member Since: 07 Apr 2010 Location: Windhoek, Namibia Posts: 42 |
Bruce, where did you get it from? Locally or imported?
21st Feb 2013 11:26am |
Heinrich it was Imported "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
21st Feb 2013 11:28am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
that doesn't sound so great... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
22nd Feb 2013 9:48am |
